RV.Net Open Roads Forum: Travel Trailers: Wheel Lugs
 > Wheel Lugs
JKQ
Posted: 04/06/12 01:13pm Link  |  Print  |  Notify Moderator
Just wondering home many check there lugs & how often. I'm thinking of purchasing a tork wrench for that purpose but wonder if It's really necessary?
2013 CruiserRv Enterra 314 RES TT, 36ft, 3 slides
2013 Ford F250 Crew Cab Power Stroke Diesel 4x4
Reese WD hitch with dual friction control bars
Dometic 3000 KW portable genset
AV8R 130
DC
Posted: 04/06/12 01:29pm Link  |  Print  |  Notify Moderator
A lot less than I should probably. I checked them after the first 50 miles a year and a half ago, and, just last week when I changed a flat.....
goducks10
Keizer OR
I never checked mine on both the new trailers I have owned. I have since taken off one tire to replace it because of excessive wear ( another story ), and will re-torque it after I put some miles on it. General rule is when installing aluminum rims, it's a good idea to drive 50 miles and then re-torque them. Then you should be good till taken off again.
Lynnmor
Red Lion
Posted: 04/06/12 01:32pm Link  |  Print  |  Notify Moderator
My dentist has a sign that says "Only brush the ones that you want to keep" Just tighten the wheels that you want to keep.
coolbreeze01
Redding, Ca
Posted: 04/06/12 01:35pm Link  |  Print  |  Notify Moderator
If you tighten the lugs with a long handle 1/2" drive breaker bar, then you probably don't need a torque wrench, but they are nice to have around just in case.........I check mine with a torque wrench about 3 times a year.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis ST Tires.........
fla-gypsy
North Florida
Posted: 04/06/12 01:51pm Link  |  Print  |  Notify Moderator
Checked mine a few times with a torque wrench and never found a problem. I check them a lot less now. Probably need to check again
wrenchbender
Phx
Posted: 04/06/12 06:23pm Link  |  Print  |  Notify Moderator
I lubbi torque mine once a year to 95 ftlbs after I lube the bearings and check on the remaining meat on the shoes.
Bob/Olallawa
Kitsap Co, WA
Posted: 04/06/12 02:05pm Link  |  Print  |  Notify Moderator
Don't know how I would get by with out a foot-pound torque wrench. Wish I had a 3/4" drive instead of the 1/2 inch. That is on my upgrade list and will happen this year for sure.
Lord, grant me the serenity to accept the things I cannot change, the courage to change the things I can, and the wisdom to hide the bodies of those people I had to kill because they pissed me off.
skipnchar
Topeka or somewhere else
Posted: 04/06/12 03:49pm Link  |  Print  |  Notify Moderator
If the wheel has been removed I recheck lugs after a hundred miles or so. Never check them again after that until the wheel has been removed again.
Chuck&Gail
In the Colorado Mountains
Posted: 04/06/12 06:53pm Link  |  Print  |  Notify Moderator
I check mine WITH A TORQUE WRENCH several times a year.
Note just using a breaker bar could result in loose bolts, or in stripped threads, or in weakening the bolts. Depends on lug torque spec, length of breaker bar, and personal strength. That being said I personally know people who are so good I would trust them to do it with anything, but not many people are that good.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
 > Wheel Lugs
