RV.Net Open Roads Forum: Tech Issues: 20A 30A adapters
 > 20A 30A adapters
mike4330
Virginia
Posted: 04/06/12 01:36pm Link  |  Print  |  Notify Moderator
Hi Folks,
Can you recommend a source of inexpensive 20A30A (TT-30 and L5-30R) adapters? Most of what I've found is in the $30 range, which seems very overpriced.
Thanks!
Crazy Ray
Monroe,La
Posted: 04/06/12 01:54pm Link  |  Print  |  Notify Moderator
Wally World in there RV section.
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
pianotuna
Regina, SK, Canada
Posted: 04/06/12 01:56pm Link  |  Print  |  Notify Moderator
Hi,
Walmart sells both a dog bone type and an inexpensive molded plug. I get much better service from the more expensive dog bone type.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
PapPappy
Wilmington, NC
Posted: 04/06/12 01:58pm Link  |  Print  |  Notify Moderator
You looking to plug in the RV (30A) in to a 20 outlet? I bought my adapter at Walmart, and I don't remember, but it was probably about $10-15.
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
korbe
Northern California
Posted: 04/06/12 03:25pm Link  |  Print  |  Notify Moderator
I have the $5 adaptor type without any problems. I use it while plugged in at home. Love to hear why the more expensive dog bone type is better.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
JLTN_James
Colorado
Posted: 04/06/12 03:35pm Link  |  Print  |  Notify Moderator
mike4330 wrote:
Hi Folks,
Thanks!
A TT-30R to NEMA 5-15P adapter is easy to come by at WM for around $5 & up. The TT-30R to NEMA 5-20P is not as common.
The locking receptacle makes it more expensive. Unless you have a locking receptacle you plan on using regularly, and it's needs to be locking for other devices you use, then consider changing it to a TT-30R. Then no adapter is needed. I've yet to see a CG with twist lock receptacles.
Remember that a 20A plug will have one blade perpendicular to the other. A 15A plug has parallel blades.
2004 Toyota Tundra SR5 (V8, 4WD, TP, TRD)
2005 Fleetwod Allegance with axle flip
Honeywell 2000i Generator
Me, DW, DS, DD, Dog & Camping Kitty
mike4330
Virginia
Posted: 04/06/12 04:43pm Link  |  Print  |  Notify Moderator
Thanks guys. I have a 10/3 extension cord with 20a ends that I want To run between my rig and my two honda2000s running in parallel. Bad idea?
Maybe hacking off the 20a ends off the cord and replacing with tt30s would be a better solution?
smkettner
Posted: 04/06/12 06:42pm Link  |  Print  |  Notify Moderator
Ah ha!
You can custom make an adapter here for $63:
http://www.stayonline.com/custom_power_cords.aspx
Or you can buy the ends at Home Depot and 1' 10/3 cord to connect them.
Or just buy the L5-30 and put it onto your 10/3 extension. You still need a 30/20 adapter for the RV like this:
Marinco 30/20 on google (real 20 amp)
Otherwise yes you can just convert the 10/3 extention to TT-30 extension cord.
* This post was last edited 04/06/12 07:51pm by smkettner *   View edit history
675 watts solar
skipnchar
Topeka or somewhere else
Posted: 04/06/12 03:36pm Link  |  Print  |  Notify Moderator
Walmart has them for less than most. Here's ONE of them for $16.00
http://www.walmart.com/ip/Road-Power-30-50-Amp-RV-Power-Adapter-Cord/16817358
Sorry that was 30 amp to 50 amp. Here's one that's 15 to 30 for $8.00
http://www.walmart.com/ip/Road-Power-15-30-Amp-RV-Power-Adapter-Cord/16817355
smkettner
Posted: 04/06/12 03:39pm Link  |  Print  |  Notify Moderator
L5-30R? what the hey is that?
You say 20/30 but then both say 30.
Are you plugging a 30a RV into a standard 15 amp outlet? (NEMA 5-15R)
If so here: $2.35 @ tweety's
My experience has shown the dogbone style runs cooler.
 > 20A 30A adapters
