RV.Net Open Roads Forum: Class A Motorhomes: Patching Fiberglass Roof After Item Removal
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > Patching Fiberglass Roof After Item Removal
Dale.Traveling
Newport News, VA
Posted: 04/06/12 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Reuse the hardware that held the antenna in place. Spread sealant on the threads and screw back into the holes. Then cover the heads with sealant. Use the left over sealant to reseal your bathroom sky light, vents, TV antenna, what ever else on the roof.
2006 Hurricane 31D aka 'Moby' the Whale
FCC(SW) US Navy Retired 1980-2003
Stella my Navigator
Bogart the All American RV Dog
and
Cocoui waiting for me at the Rainbow Bridge
Wherever I happen to park
Posted: 04/06/12 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
If the sat antenna is like mine, all you will have is a few bolt holes, If the roof is rubber, Dicor caulk (the non self levelling kind) works just fine for small holes.
Or you could use a 11x11" slab of Eternabond cut into 4 pieces (5.5 by 5.5" each)
Either method should work great.
wny_pat
Western NYS
Posted: 04/06/12 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
rgatijnet1 wrote:
I would use fiberglass resin and a small amount of cloth. The trouble with some automotive fillers is that they may not expand and contract the same as the fiberglass, which may cause a leak, if they separate. Small fiberglass repair kits are available at most auto stores.
X - 2! That way it is done right.
Daveinet
il
Posted: 04/07/12 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Bingo. Just put the bolts back in the holes with sealer and call it good. Its on the roof, no one can see it. Beside a couple of bolts into the roof isn't going to look bad. You never have to worry about the repair going bad or cracking. Simple solid solution.
Dave
The Flying Fortress
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Howell/GM 16197427 ECM/Edelbrock MPFI,Thorley's & Magnaflows,
4L85E 4 speed, KoniFSD,
6% grade = wanna drag?
MISC photos
Revconeers Forum
CarlGeo
Central San Joaquin Valley, CA
Posted: 04/07/12 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
Three (3)years ago I removed the same hardware from my roof and repaired the holes with Eternabond.
Cut small 4" square pieces and place over screw holes and use larger pieces where coax cable penetrated roof membrane.
ETERNABOND is the best and probably the easiest to use!
SCVJeff
Santa Clarita, CA.
Posted: 04/07/12 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
And that's exactly what it's meant for. No sanding and grinding with a finish that may well crack, and looks far worse than a flat white patch. Eternabond simply won't come off prepped correctly.
Jeff - WA6EQU
rvrepairnut
bc
Posted: 04/07/12 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
vacuumbed wrote:
On my new to me 96 Monaco Executive I am going to remove the In-Motion satellite dish.
What is the best or most professional way to patch the holes in the roof after removal?
Thanks in advance.
seeko flex cant go wrong
vacuumbed
Salt Lake City, Utah
Posted: 04/09/12 03:16am Link  |  Quote  |  Print  |  Notify Moderator
What's the best way to get this white paste off? Is there a chemical that will soften it or does it just have to be scraped off?
Dale.Traveling
Newport News, VA
Posted: 04/09/12 09:57am Link  |  Quote  |  Print  |  Notify Moderator
Use a heat gun/hair dryer to warm it up and a plastic putty knife to scrape off. Acetone and cloth rags will help get the remaining sealant off. Take your time and don't rush scraping the material off so you don't stress or damage the roofing material. Doesn't require a lot of heat. A hot day in direct sun may even be enough to soften it so you can scrape if off.
Try and get as much of the sealant off before you actually try and remove the dome so you don't risk damaging the roof.
rvrepairnut
bc
Posted: 04/09/12 10:05am Link  |  Quote  |  Print  |  Notify Moderator
thats not required and is a messy waste of time.Simply fill holes with the bolts removed and seeko flex them and any wires holes end of story
