RV.Net Open Roads Forum: Class C Motorhomes: chassis battery drain
 > chassis battery drain
Whidbeydavid
Whidbey Island, Washington State
Posted: 04/06/12 03:21pm Link  |  Print  |  Notify Moderator
I have a 2005 Itasca Spirit 24F that has been great for us. However, I've recently noticed a problem with the chassis (engine) batttery running down within a week or so of being parked and not in use. No lights on that I'm aware of, no apparent source for battery drain. I can start the engine if I use the "Battery Boost" switch and start from the house batteries, and the engine battery itself holds a charge when I drive the rig, park it for a night or two, then try to start it from the engine battery - no problem there. chassis battery is fairly new - 1 or 2 years old only.
I did install a new radio/CD player, and wonder if that's causing a drain, although that was installed nearly a year ago and this problem only cropped up this winter. I'm wondering how many of you install a battery cutout switch on the chassis battery, similar to what the manufacturer installed on the house batteries? Can this be accessed easily from inside the cab, or do I have to pop the hood to reach it? Thanks, Dave
PapPappy
Wilmington, NC
Posted: 04/06/12 03:32pm Link  |  Print  |  Notify Moderator
I had a similar issue with our MH, and finally just use the battery disconnect switch that was on the battery when we bought the MH (used). I had to replace a battery, after it had gone completely dead, and never really charged up to full charge again......
Getting a switch isn't expensive, and is good piece of mind for when you have the RV parked for extended periods of time, and can't keep a Battery Minder on it.
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
frogkisser
TEXAS
Posted: 04/06/12 08:30pm Link  |  Print  |  Notify Moderator
I have the same problem. I paid a shop well over $400 to chase down and fix it, but they couldn't find it.
My solution is to shut down the engine by hitting the off switch for the chassis electrical. No drain when doing this. If i just shut the engine down the normal way, I get a battery drain.
NewsW
US
Posted: 04/06/12 03:58pm Link  |  Print  |  Notify Moderator
Fully charge the battery and hook up an ammeter to see.
Normal discharge is 1amp or so until it settles down then to a parasitic load of about 300ma.
You could just have a dead battery.
Has the battery been exposed to summer heat? Arizona?
Is it a "northern" battery used even one season in south?
tenbear
Northern Vermont, USA
Posted: 04/06/12 05:48pm Link  |  Print  |  Notify Moderator
NewsW is right, you need to know how much current is being drawn from the battery. A DC clamp-on ammeter is perfect for this job.
You might also check the water level in the battery.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
ScottG
Bothell Wa.
Posted: 04/06/12 06:54pm Link  |  Print  |  Notify Moderator
Has anybody added anything like an amplifier or alarm system?
Scott, Grace and Wesly
H0NDA eu2000i
Bordercollie
Garden Grove, CA, USA
Posted: 04/07/12 10:14am Link  |  Print  |  Notify Moderator
It's a good idea to keep a Battery Minder connected to the starting battery when rig is not driven for some distance at least twice per month. This will keep the battery from self-discharging and going flat from running connected devices. Your converter should keep your house battery up if plugged into shore power, but some will overcharge and boil out electrolyte damaging the house battery. Best to check electrolyte levels once per month. Otherwise you should connect a Battery Minder to your house battery too. Battery Minders are "smart" trickle chargers that can prevent or reverse sulphation of battery plates. They are good to keep batteries charged fully and extend their useful life considerably. They can be left connected with no fear of over-charging. Desulphation feature only works well on partially sulphated batteries, read FAQ's on website:
http://www.batteryminders.com/details.php?prod=12117
NewsW
US
Posted: 04/07/12 11:45am Link  |  Print  |  Notify Moderator
If you are careful, a 10Amp max. in line ammeter will work as long as there is not a big surge load when the battery is first connected.
But the clamp on is best.
The 1-3 amp phase is the "wake" current of the vehicle (all computers) and then it goes to sleep mode, consumption 300ma after about 5 min.
Things like interior lights on, etc. add to the load.
tatest
Oklahoma Green Country
Posted: 04/07/12 11:51am Link  |  Print  |  Notify Moderator
Do you switch the radio to the "house" setting? I can usually store 2-3 months if the battery is just keeping the memory in the ECM alive, but can run it down in a week or less if it is supplying the turned-off radio.
This gets progressively shorter as the battery ages, and loses it's capability to hold a full charge.
What we do with these batteries, long periods of storage with low level loads, often high temperatures, pulls them down to discharge levels well below what they were designed for. This kills them faster than using them for a start, and fast recharge, every day or at least a couple times a week.
Pulling the ground connection will remove all loads. I don't like to do this because the ECM has to learn all over again about my driving and the condition of the engine and transmission, but if the battery goes too low that happens anyway.
If the battery self-discharges in less than two-three months, when totally disconnected, it is time for a new battery.
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
Gene in NE
Omaha
Posted: 04/06/12 08:49pm Link  |  Print  |  Notify Moderator
Hopefully this comment might help someone. I had a similar problem with my RV, the chassis battery would sit all winter and be ready to go in the spring. (often between October until April the next year) Then something happened and the RV battery was dead in 30 days.
I connected a set of jumper cables to the chassis battery and immediately my OBD2 monitor lit up and chirped without me even touching the ignition switch. I immediately learned the problem. I thought the OBD2 went completely dead when shutting off the ignition, but apparently it stayed live and connected merely shutting off the display.
The next time, I unplugged the 8-pin modular connector from the ODB2 and lo and behold the chassis battery remained fully charged for the next 2 months.
2002 Trail-Lite Model 211-S w/5.7 Chevy (click View Profile)
Gene
