recycler
michigan
sounds like several things led up to it i think the way you handled it was best...it could have been worse
1968 franklin 11fk
back to my 93 cummins
Old-Biscuit
Across the USA
Moving vehicle vs parked vehicle.
Glad you are "a hard core conservative thinking kind of guy who believes strongly in personal responsibility".
Did you give them your phone number and insurance company so they can get their vehicle repaired?
bigdogger
Old-Biscuit wrote: Moving vehicle vs parked vehicle.
Did you give them your phone number and insurance company so they can get their vehicle repaired? What he just said.
4x4ord
Canada
I had someone unhook his horse trailer in my driveway without permission. When I went around it on the right the righthand tire of my horse trailer went over a mound tipping a guard that protects the light switch up on the top of my trailer into the side of his trailer. His aluminum trailer was scraped down the side. I offered to split the cost of fixing his trailer - he was outraged and so I ended up having to cover the $2000 bill to fix his little scratch.
2011 F350 SRW short box 4x4 CC 6.7 PS King Ranch
B&W TurnoverBall and Companion
2003 Citation Supreme 34 RLTS
Rvpapa
Alberta , Can.
Think you were real lucky that the kid wasn't standing there.
Art.
MadMav
Colorado Springs, CO
bgum wrote: Who hit Who? That will give you some idea as to fault. You did the right thing.
Ditto, good job.
Mav
"A fifth wheel trailer is a bi-level towable mobile home."
RandK-M
NY
My understanding is it would be your fault completely. You were moving and they were parked. You're responsible for checking to make sure your path is clear before moving. It's the same as if you backed out of a parking spot with your truck and into a car stopped behind you.
Luckily, it was only a door and not the kid.
Lastly, regardless of what happened or who's fault, "Hispanic" is completely irrelevant to the entire story. It doesn't mater whether they were Hispanic, White, or from the planet Mars. What does that have to do with anything?
Ray
Jayco 17Z
Dodge Ram 1500 Quad Cab
Prodigy P2
Equal-i-zer Hitch
US Navy Veteran
tr1jr2
Pittsburgh
If the person is out of the vehicle it's your fault, no question about it. If the person thru open the door and you hit while they are still in the vehicle it's their fault. Doesn't matter where the parked vehicle is, lot, street, field etc. You hit a stationary object. Your fault. I do commend you for in your mind you thought it was their fault and you just said forget it. Prepare for good Karma.
coolbreeze01
Redding, Ca
A wreck at the dump with a poor family? What if you had hit some ambulance chasing lawyers properly parked vehicle? I'd keep an eye on those fenders.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
skipnchar
Topeka or somewhere else
If the other vehicle was sitting still and yours was moving I suspect you would have been adjusted to be at fault for the accident. Now if the damage occurred when they opened the door and it hit your truck, the decision would have gone the other way. I'm not a lawyer but I DID watch Peoples court
Good luck / Skip
