RV.Net Open Roads Forum: Do TT's plug into a 20 or 30 amp receipitcal?
 > Do TT's plug into a 20 or 30 amp receipitcal?
smkettner
Posted: 04/06/12 08:06pm Link  |  Print  |  Notify Moderator
zackyboy3rs wrote:
I thought I was thinking correct. I had an electrician install a 30amp box and a separate breaker. I plugged in my tt and it trip and noticed a burning smell. Knocked out all my power. Fix: new power converter install.
I plugged in my dads tt and heard a pop. Little bit of smell and again no power. 3 breakers tripped in tt. Plugged into 110v with adapter and everything works. Called my electrician and tried to explain the problem and he said he had no idea what caused the problem but he would come check it out.
I suspect he wired 240 volts
Multimeter will tell. Or check if power come off one(120v) or two(240v) pole breaker.
675 watts solar
zackyboy3rs
Eastern North Carolina
He put in a new 30 amp breaker and ran new wire from my panel box.
2010 Jayco Select 29L
2009 Chevy Silverado LTZ 2500HD 6.0L, 3.73, Gas sipper
zackyboy3rs
Posted: 04/07/12 03:13am Link  |  Print  |  Notify Moderator
x2
Not sure.
Is it 120 or 240?
zackyboy3rs
Not sure
westend
all over
Posted: 04/07/12 06:03am Link  |  Print  |  Notify Moderator
Is it possible that the electrician wired in 30 amp 240 volt service instead of the required 30 amp 120v. service for TT's?
'03 F-250 4x4 CC
Kiwi_too
Western, WA
Posted: 04/06/12 08:18pm Link  |  Print  |  Notify Moderator
x2
Is it 120 or 240?
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
zackyboy3rs
Posted: 04/07/12 07:27am Link  |  Print  |  Notify Moderator
I am taken it in for repair next week. Still under warranty but without a doubt something is not right with the work the electrician did. I will keep y'all posted in case it happens to someone else. Thanks
RJsfishin
Winston Or.
Posted: 04/07/12 07:47am Link  |  Print  |  Notify Moderator
Don't ever put in more than a 15 amp service if guests are going to be staying in the RV ! You will kill 2 birds w/ 1 stone,.......cheaper power bill, and guests won't overstay their welcome !
Rich
'01 31 ft Rexall Vision, Generac 5.5k, 9245 conv, 400 watt inv, 2 12v batts, ammeters, KingDome/sat, Two Oly Cat heaters, and towing a '05 Jeep Liberty, or sometimes towing a Lowe bass boat.
Bucky Badger
Madison, WI
Posted: 04/07/12 06:06am Link  |  Print  |  Notify Moderator
zackyboy3rs wrote:
Not sure
Sounds like you "electrician" hooked you up to 240v (double pole breaker)...if so, He should fix anything that burned up.
Fred & Jodie, dogs, Zoey & Mika
RIP Bella
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
fla-gypsy
North Florida
Posted: 04/07/12 06:42am Link  |  Print  |  Notify Moderator
240 volt + TT = burned up components($$)
