RV.Net Open Roads Forum: Fifth-Wheels: toliet not holding water
 > toliet not holding water
star52656
north carolina
Posted: 04/06/12 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
after flushing the ball will not close all the way and the water leaks out. If we push the foot pedal and let it snap back it will hold water. Quick fix for this or do I have to pull it to fix it... thanks
greende
Syracuse,NY
Posted: 04/07/12 04:13am Link  |  Quote  |  Print  |  Notify Moderator
Had the same problem with our Cougar TT. Under warranty they just replaced the seal. Parts changing. When it happened again, I cleaned the blade and the seal and bought some plumbers grease at the big Orange (or Blue) home store and applied it to the seal and blade in a thin coat. Worked. Your results may vary.
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
KMC6970
Houston, TX
Posted: 04/07/12 05:45am Link  |  Quote  |  Print  |  Notify Moderator
I use a touch of vasiline.. works for me. keep a jar handy to rub on the ball.
Dave H M
IL
Posted: 04/07/12 06:45am Link  |  Quote  |  Print  |  Notify Moderator
I guess it depends on what toilet you have. On the dometic in mine you can change the seal by holding the ball open with your foot and reaching in there and R&R the seal.
kakampers
Fulltimer
Posted: 04/07/12 07:09am Link  |  Quote  |  Print  |  Notify Moderator
We've always used the "let it snap back" method....seals everytime, and hasn't hurt anything in decades of RVing....
2013 Heartland Landmark Key Largo with Mor Ryde IS and disc brakes
2011 Chevy Silverado 3500 DRW Crew Cab Duramax Diesel
kennethwooster
Perryton Tx USA
Posted: 04/07/12 09:22am Link  |  Quote  |  Print  |  Notify Moderator
I've also used the snap back method, but I prefer to clean and add vaseline. That usually takes care of the problem. If this does not solve problem, then it need to be resealed.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F250 2011 model, 4X4, King Ranch.
18K SuperGlide Hitch
BlackSilver
East of Heaven, North of Hell
Posted: 04/07/12 10:03am Link  |  Quote  |  Print  |  Notify Moderator
We have a Thetford. Snap back (or lift the valve handle with your toe) has been working for years. Changed the rubber seal after about 4 years --- may be due again during my spring maintenance cycle.
Hans, KØHB & Colleen, KØCKB
Master Chief Radioman, US Navy
Prairie Schooner 34FBR Platinum XL Camping Trailer
3500HD Silverado Big Dooley LTZ Go-power by Max & Allie
My rig (Click)
cabanaman
florida
Posted: 04/07/12 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Been using the flip back method for years,lubing it helps but don't last long.
Retired Navy
2007 Dodge Ram 2500 quad cab 6.7 cummins,6 speed auto,exhaust brake.
2007 Open Road 378SA4S-5,equa-flex and morryde X factor,wet bolt kit,michelin ltx M/S 2 tires
http://www.gofundme.com/Carebear (my daughter)
LostinAZ
At Home
Posted: 04/07/12 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Might also try put some vegetable oil in the standing water when it is closed properly. A few applications should soften up the rubber gasket and help it seal and close better. This is a band-aid fix however. Eventually you may have to replace the rubber gasket. Caution: Do not use a petroleum based lubricant.
routemaster
Deming
Posted: 04/07/12 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
We found that we change out ours every year fulltiming with hard water around.
2005 GMC 2500Dmax C/C S/B with 06 air box.
Reese 16k Slider hitch.
2006 Everest 344J.3500lbs springs, Monroe shocks, LED taillights Travelsoft water softener.
YAMAHA EF3000iSEB
Fulltimers
Verizon Air Card.
