RV.Net Open Roads Forum: Dinghy Towing: Seven pin to a 4 pin
Search only in Dinghy Towing
 > Seven pin to a 4 pin
rvten
Crossville,TN
Posted: 04/06/12 07:05pm Link  |  Print  |  Notify Moderator
Your new MH should have came with male/female plugs. Simple enough yo wire the four wire cable to the 7 pin plug. Have done this several times.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is no B+
kaydeejay
SE Michigan, USA
Posted: 04/06/12 07:07pm Link  |  Print  |  Notify Moderator
FedAgent wrote:
kaydeejay wrote:
FedAgent wrote:
The motorhome I bought has a seven pin connection. My last motorhome and my current toad has a four pin setup. I have looked all over the net for a seven pin to a four pin round adapter, but have not found one. I found a new cable, but surely someone makes a plug in adapter that is cheaper than a new $70.00 cable. Any thoughts?
Thanks
How are you getting a signal to the toad brakes?
It's a Brake Buddy, activated by inertia.
OK, that makes sense now. Thanks.
Keith J.
1999 Sunnybrook 27RKFS Fiver.
2005 GMC Sierra 2500HD CC/SB/DA 2WD, LBZ air cleaner, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax cover, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors, TST TPMS.
D.E.Bishop
Eagle Rock, CA
Posted: 04/06/12 07:19pm Link  |  Print  |  Notify Moderator
I would guess due to the lack of responce on your side that your MoHo has a seven flat pin socket and that you want to go to a four pin round socket. i would suggest either building your own from the appropriate ends and a short piece of four conductor # 16 cable or buying a round four pin socket and a couple feet of four conductor cable and wire it parallel to the seven conductor outlet and either zip tie it to something or buy a mounting bracket and mount it near the seven pin socket.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
1990 Bounder 27D
1995 Suzuki Sidekick 4X4
Stowmaster 5000
old guy
Oregon (pronounced Or e gun)
Posted: 04/06/12 09:54pm Link  |  Print  |  Notify Moderator
you can go to a equipment rental place. they have all that stuff for their customers.
