RV.Net Open Roads Forum: Coach shuts down when turn signal given.
 > Coach shuts down when turn signal given.
Gasman 2
Caldwell, Ohio 43724
Posted: 04/07/12 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
The lost of brakes is puzzling here. The only thing electrial in the brake system is the ABS and brake lights. Lost of either would not keep the brakes from functioning. Lost ABS would only effect the anti skid function??
Gasman 2
rvrepairnut
bc
Posted: 04/07/12 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
loosing the brakes would not have anything to do with the electrical
U will soon run out of air and then NO brakes but your rear brakes will dynamite on but Iam sure your able to pu;; off the road before this happens/ your power steering gone soon as engine shuts off
Question? what happens if you then turn the signal off does the engine refire right away?
mdock2
Posted: 04/07/12 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
If the OP's system is like mine and reacts the same, then yes he loses his power brakes and steering. Mine resets after about 90 seconds. Thus, he is losing all power including lights, etc.
And yes, hope he does post updates.
Marty (KI4NAI)& Shirley
1998,38' DutchStar F/L Cat
MEMBERSHIPS
FMCA
Bits & Bytes,
Elks International (Webmaster)
FCCC
PPA (Life Member)
Moose
ARRL-ARES
National Park Travelers Club
Visited 158 National Parks
Places we've slept since 2007
RayChez
Barstow, Ca. USA
Posted: 04/07/12 11:15pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with Dennis. I think you have a short in your harness somewhere in the steering column.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
RayChez
Barstow, Ca. USA
Posted: 04/07/12 11:17pm Link  |  Quote  |  Print  |  Notify Moderator
What is so puzzling about losing everything. When the engine dies you will lose power steering, air brakes.
chewbear
Mobile in the USofA;currently Ozark, Alabama
Posted: 04/08/12 12:34am Link  |  Quote  |  Print  |  Notify Moderator
Dumb suggestion disconnect toad harness, just a thought.
2002 Fleetwood Discovery
330 cat. '09 Escape toad.
Kathy & Joe wish you well.
My mind works like lightning,
one brilliant flash and it's
gone. (Maxine)
dennyR
Holland, Michigan
Posted: 04/08/12 05:52am Link  |  Quote  |  Print  |  Notify Moderator
After changing a brake light bulb, my CAT would quit running. With help, I found a short in the light socket.
2000 Newmar Dutchstar DP
2004 Road King
1994 Jeep Wrangler
randallb
On the road
Posted: 04/08/12 06:10am Link  |  Quote  |  Print  |  Notify Moderator
I think Denny may be on the right track. Ford also grounded part of their ECU on the 90's Thunderbirds through a taillight. A burnt out bulb caused all kinds of problems. Corrosion or an incorrect bulb could be the issue in this case. Have you had any light bulbs replaced recently?
Randy
Gasman 2
Posted: 04/08/12 08:43am Link  |  Quote  |  Print  |  Notify Moderator
On the question of loss of air brakes when the engine stalls or quites please reference Subpart B - Federal Motor Vehicle Safety Standards standard No 121 air brake systems and perhaps you can understand the safty build into air brake systems. So in the event the engine does quite or stalls you do not lose your brakes.
Please think about this: If you pull up behind a heavly loaded 18 wheeler at traffic light on an up grade and he stalls his engine when he releases the clutch he is not going to coast back into to you because there is still air in the air tanks for the brakes to fuction. Even if that fails and the air pressure drop below 40 or 50 lbs the springs brakes will setup.
RayChez
Barstow, Ca. USA
Posted: 04/08/12 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Gasman2, it is true you still have air in the air tank and have brakes for a couple of applications. Eventually you will run out of air and the spring brakes will lock up the rear brakes only. If the coach is going at 60 mph on a long grade down hill and if the engine dies it would be almost impossible to steer without power steering. Your brakes would eventually stop the coach, but not with air.
