RGordon
Atoka, TN/North Ft Myers, FL
While returning home from snowbirding in Florida, a truck driver flagged me over to the side. I found the living room large emergency exit window loose and flopping at bottom and just hanging at top by one side. This was a safety hazard to others as well as expensive to replace. Found the screws had backed out of the red plastic holder and fell to floor, allowing the other side to work loose allowing window to be sucked outward by passing big trucks. Just passing on my bad experience and lucky no one got hurt.
Ron & Libby Gordon
07 Ford F350 Dually Tow Boss Diesel
07 Mobile Suites 38RL3 #3698
02 Winnebago Adventurer 35U V10 (Former RV)
Learn from yesterday, live for today, hope for tomorrow
jf831024
South Louisiana
Thanks for the heads up!!!
2011 Fuzion Touring Edition 3
2009 Chevy Silverado 2500HD LTZ Duramax Diesel
Chris
Shelter Bay, Wa
Saw a bedroom one flapping between Surprise and Kingman a few days ago. Yesterday we followed a MH with a basement door flapping. Chris
My Rig
2001.5 2500 STD CAB AUTO SLT 4x4, CTD 4:10's, Bomb'd to Tow
2005 Cardinal 29WBLX.
rattleNsmoke
Western Conn.
Wow. I couldn't imagine that window being launched down the highway. After reinstalling the screws, did they hold up for the rest of the trip?
Mike
2010 Cedar Creek 34SATS (The Beast) & 20k Curt Q20 roller slider hitch
2006 Ford F350 SRW,SC Powerstroke diesel Lariat
2003 Harley Heritage Softail (Hogzilla)
and a wifey with tons of patience....
Mile High
Denver, CO
Yikes! Glad someone flagged you.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
RGordon
Yes it did hold after reinstalling the screws but do I trust it will not happen again sometime in the future. Still thinking of some way to make me feel better knowing it will never happen again. Thought about installing permanent screws, then there goes the emergency exit.
SoCalDesertRider
SanDiego, CA, USA
RGordon wrote: Yes it did hold after reinstalling the screws but do I trust it will not happen again sometime in the future. Still thinking of some way to make me feel better knowing it will never happen again. Thought about installing permanent screws, then there goes the emergency exit. I've never had one of those pop-out emergency exit side windows. My campers always had the emergency exit roof vent instead, so I'm really not familiar with how the side windows work.
Anyhow, from your description, it sounds like the red plastic holder is what keeps the window in place and the reason the window opened was because the screws holding the holder to the camper framing backed out?
I would inspect the holder to be sure it is still in useful condition. Use as-is, or replace as necessary. Then use the next size larger screws to screw the holder back on and use a little wood glue on the screw threads to help ensure they don't come loose again.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
MrD
Washington
There is probably a way to secure the window while traveling, an extra latch, that can be undone while camping so you can still use the emergency exit while camping.
Mike
Mike and Char
2008 Chev 3500HD D/A Ext cab LB D/A 4x4 dually
B&W companion hitch
2013 Arctic Fox 295K
drwwicks
Alabama
It might be possible to secure the lower latch using safety wire. In aviation where you need to secure a switch or latch, but be able to move it if necessary, copper break-away wire is used just like steel safety wire. If you try it, use the thin copper, not steel safety wire. Copper will break easily but the steel safety wire won't.
2011 Keystone Raptor 300MP
2012 Ram 3500 CC Dually
2011 Harley Davidson FLHTK
