silvercorvette
Anderson SC
Others have suggested that a 120 volt TV would be a better choice and after doing some checking I believe their advice was correct. By the way I also had my opinion changed about getting a diesel generator and after listening to the good advice of the people on this forum I got a Yamaha 4.500 KW generator.
First of all the 12 volt TVs are about double the price of a 120 volt TV.
I also read that manufactures such as Jensen (the brand I was considering) are cheaply made by some unknown manufacturer and Jensen just sticks their name on it but you eventually will wind up with an unrepairable TV. I had the same thing happen with a TV I bought at sam's club, they could not get parts to fix the set but sam's club was nice enough to send me a check for the set under extended warrantee and I used it to buy a different brans. One person mentioned that when their new TV failed it was replaced twice instead of being repaired. Eventually when the warrantee doe expire you are stuck with a TV that can't be repaired.
At this point I am looking for something around 32 inches that is able to withstand the bouncing around and is light enough to pick up and take home with me when I park the camper in storage.
I was prepared to pay about $600 for the 12 volt but I hope to be able to find something cheaper.
I have 2 Vizio 55 inch LCD TVs that are about 4 years old that I am very happy with and a 32 to 35 inch Panasonic 10 to 15 year old TV with an old fashioned picture tube that still has an excellent picture.
What brand TVs do you have in your camper that has held up well to the bouncing around in your camper?
I picked 32 inches because they aren't too heavy or expensive but I will go much larger as long as the weight stays under 35 to 40 pounds.
I am not even sure if bouncing around will have any effect on a modern solid state LCD TV but I figured I should ask to make sure before spending a few hundred bucks.
2010 Dodge 409 CI diesel long bed dually crew cab B&W hitch, 95 Gallon Auxiliary Transfer Fuel Tank, pulling a 33 foot Holiday Rambler Alumascape suite, Winegard SK-3005 TRAV'LER , Central vac, Splendide 2100 XC washer dryer, Rotochoks, TST Tire monitor.
rk911
Wheaton IL
we have two sharps in our MH...a 32" and a 17". going on 3 or 4 years now and no problems.
73,
rich, n9dko
www.bananaboatbytes.com
I know a guy who's addicted to brake fulid. He says he can stop anytime.
2000 Itasca Suncruiser 35U
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
smkettner
My 19" Toshiba has been fine. Probably time for me to upgrade.
Saving the $300 would pay for a small sine wave inverter to power the 120v tv and other small toys.
675 watts solar
bluestek
San Francisco East Bay
Samsung
silvercorvette
Anderson SC
I have a 75 watt inverter that came as standard equipment in my dodge pickup. I also own a Black and Decker 750 watt inverter that I plan on using when I am not running the generator. The truck has two 12 volt batteries and the camper has a 12 volt deep cycle battery. Most of the 12 volt TVs seemed to use less watts than a 120 volt TV and that was the reason I wanted the 12 volt but I figure that even if I drain all 3 batteries and get stuck in BF Egypt I still can fire up the generator and connect it to a battery charger then use that to start the truck.
PS I assume the B&D will provide clean power
Peg Leg
Anderson, IN
I have a 32" LG in the TT. I have it bolted to a shelf with a angle support that is bolted to the back from the shelf. I did have to drill 2 holes in the base.
The LG has an excellent picture and a strong tuner. I've used it now for 3 seasons.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
06 Hitchiker II LS 29.5 FKTS
Yamaha EF3000iSE
retired gadgetman
The Texan
Cascade or Meridian, Idaho
We have a 32" Sharp Aquos in our RV and working in the oil fields, it gets some bouncing between sites. Probably going to Jinx myself, but it has worked flawlessly for 3 years now.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
Kiwi_too
Western, WA
Vizio
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
ScottG
Bothell Wa.
Samsung.
Scott, Grace and Wesly
H0NDA eu2000i
dahkota
Washington, DC
We went with a 19" VIZIO because it had the lowest power load we could find (20W) including 12V TVs (at a better price too). Works great and has been banged around a lot.
2008 Ford F250 diesel
2013 Keystone Sprinter 277RLS
