RV.Net Open Roads Forum: Which brand water heater uses an anode rod?
 > Which brand water heater uses an anode rod?
I am still wayne_tw
everywhere
Posted: 04/07/12 06:38am Link  |  Print  |  Notify Moderator
Is it the Atwood or Suburban that uses the anode rod?
* This post was edited 04/07/12 09:30am by an administrator/moderator *
BB_TX
McKinney, Texas
Posted: 04/07/12 09:47am Link  |  Print  |  Notify Moderator
Suburban
Airstreamer67
Pineville, LA USA
Posted: 04/11/12 04:28am Link  |  Print  |  Notify Moderator
Well, I don't know what my aluminum tank did wrong, but it developed a hole that looked like it was caused by corrosion. Perhaps it didn't technically rust, but the effect was similar.
Chris Bryant
DeLand, Florida, USA
Posted: 04/11/12 05:14am Link  |  Print  |  Notify Moderator
The entire inside of the Atwood tank *is* the anode. Atwood uses an inner cladding of an Aluminum/magnesium alloy- the surface area is many times that of a rod, but.... you must flush the Atwood at least once a year (more is better).
The Suburban anode is basically there to protect the final welds- they assemble the entire tanks except for the "flame cup" where the burner is, then they spray the inside with the porcelain slurry and fire the tank, and then they weld in the flame cup. This means that weld is not "glass lined" (along with any breaks in the glass), so you have a very small area with the galvanic action concentrated there.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
Old-Biscuit
Across the USA
Posted: 04/07/12 10:41am Link  |  Print  |  Notify Moderator
Correct......
Suburban uses an anode rod.
BUT thanks to marketing......a confusion occurs because you can purchase an anode rod for an Atwood water heater.....which doesn't use an anode rod
Just one more way to separate you from your money
ScottG
Bothell Wa.
Posted: 04/07/12 03:08pm Link  |  Print  |  Notify Moderator
Suburban needs an anode because it's a glass lined steel tank (like your home unit) and will eventually corrode without one. The Atwood is aluminum and will never rust.
Scott, Grace and Wesly
H0NDA eu2000i
