RV.Net Open Roads Forum: Fifth-Wheels: Generator
 > Generator
rvgwen
Texas, Aransas Pass
Posted: 04/07/12 10:34am Link  |  Print  |  Notify Moderator
Hello, In the process of ordering the Montana fifth wheel and have a question on the generator option. Do most of you order the generator prep., the generator installed or nothing at all. Can a after market generator such as the Honda 3000 be used in the generator compartment. Thank you for your help.
dbbls
Missouri
Posted: 04/07/12 10:41am Link  |  Print  |  Notify Moderator
To run a generator inside the unit it must be isolated from the rest of the compartment. You will also need about 1 square foot of opening in the door for ventilation. Generator prep should give you these items. There should also be a junction box which you can hard wire the generator into. The generator exhaust would have to be extended outside also.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
nremtp143
Georgia
Posted: 04/07/12 10:45am Link  |  Print  |  Notify Moderator
We ordered the generator prep on both of ours. Of course we put an Onan in them though.
2012 Sandpiper 365SAQ, Goodyear G614s, TST TPMS
2010 F350 DRW 6.4L 4x4, Edge CTS, B&W Companion, Viair 10007 air system, Firestone Ride-Rites,Flo-Pro cold air pipe
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
45Ricochet
North Idaho
Posted: 04/07/12 11:12am Link  |  Print  |  Notify Moderator
It came prepped and CW installed the Onan.
The Honda would work fine being stored in the area but I wouldn't run it in there.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
pianotuna
Regina, SK, Canada
Posted: 04/07/12 11:13am Link  |  Print  |  Notify Moderator
Hi,
I find generators annoyingly loud. I'd not willingly have one that was built in. Generator prep would be my choice in case I changed my mind.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
PapPappy
Wilmington, NC
Posted: 04/07/12 11:14am Link  |  Print  |  Notify Moderator
Haven't done it, but a friend told me that he would order his FW with the "generator Package", for the wiring hook-ups. He would then find a generator that would fit his needs. Not sure just what generator he used, but he did say that he saved a few thousand bucks
I would assume that when the mfgr sets the rig up for a generator, they are taking the air flow and other things into account....but don't quote me
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
RoyB
King George, VA
Posted: 04/07/12 12:12pm Link  |  Print  |  Notify Moderator
Generators are nice to have but alot of places you will visit may have generator run time restrictions. I havent found any place I go to that allows free use of the generator. The norm is 8AM-10AM and then again 4:30Pm-7:30PM at most sites. It is more of a problem on the Eastern side of the US then the Westernern side I think. I quess there is more open space on the western side.
Here on the East side doesnt give you much time to run a generator for air conditioning so most folks that like to camp off the power grids usually just end up running their generator just to re-charge their batteries up every day in the short time period being allowed to run their generators...
Even the Govt run sites here on the east side have generator restriction run times in force.
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
dlturner00
Tennessee
Posted: 04/07/12 12:26pm Link  |  Print  |  Notify Moderator
Be VERY careful if you install a generator in the compartment yourself. The exhaust has to be run to the outside in a safe location. CO will kill you in your sleep and you will never wake up. A family died here in Tennessee last year and their generator was outside on the ground. Biggest problem was faulty CO detector. Just a word of caution.
David
2004 F350 CC 4WD DRW Powerstroke
B&W Companion Hitch
Prodigy Controller
2013 Cedar Creek Silverback 35QB4
Mile High
Denver, CO
Posted: 04/07/12 12:43pm Link  |  Print  |  Notify Moderator
Definately get the generator prep and 2nd AC prep on that Montana, and if they still charge for it - the satellite prep. All of these are good selling points and save a lot of cost later if you decide to install a generator, AC or satellite dish.
Both of our Montana's were ordered with the Generator Prep. They are tailored to the Onan and come with a heat sheild that isolates the generator from the rest of the coach, an automatic transfer switch, start stop switch with hour meter (typically in the bedroom), the pop-out circuit breakers, and a kick-out panel through the bottom that gets removed when you install the generator. I installed our 5500LP myself after removing it from the old 5er and it was a piece of cake with that prep. The majority of Onans now draw air and exhaust cooling air through the bottom kick-out so you don't need a vent in the cabinet door anymore. The exception is the Micro-lite.
The cabinet is not designed for portable generators, as they cannot adequately vent the heat, fuel vapors, or exhaust.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
dannytas
Pioneer, CA
Posted: 04/07/12 01:28pm Link  |  Print  |  Notify Moderator
Wish I would of got the gen prep on my new fiver. Had a built-in gen in my class C. Quiet and conveient, just push the button on.
'12 Keystone Cougar 297RKSWE
'03 Dodge 3500 QC 4X4 Long bed Dually
DW-Lynn
BigDog-Kelley
LittleDog-Kroozer
 > Generator
