RV.Net Open Roads Forum: Fifth-Wheels: Worn tire question.
 > Worn tire question.
Chippendale
Austin, TX
Posted: 04/07/12 11:38am Link  |  Print  |  Notify Moderator
I just noticed that the inside half of the tread on the rear tire on the drivers side of my 5th wheel is almost smooth, the outside tread looks pretty good, and the other three tires look fine. What do you suppose would cause a tire to wear like that and no other tire be affected?
agesilaus
North Florida
Posted: 04/07/12 11:40am Link  |  Print  |  Notify Moderator
Alignment pops to mind
Glendale Titanium 29E34TS fifth wheel
PullRite OE Series Super5th 18K
Superbumper
donn0128
Pronounced Ore-gun
Posted: 04/07/12 11:42am Link  |  Print  |  Notify Moderator
X2
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
Old-Biscuit
Across the USA
Posted: 04/07/12 12:10pm Link  |  Print  |  Notify Moderator
More so than alignment I'm thinking bent hub........look at tire/wheel directly from rear....is it leaning out at bottom (in at top) or is it cocked?
Leaning (top to bottom) somethings bent
Cocked......could be alignment
kennyd63
Minooka, Illinois
Posted: 04/07/12 12:43pm Link  |  Print  |  Notify Moderator
It sound's to me like your alingment is off>
only my opinion>>
2005 National Sea Breeze LX 8321
2010 Forest River Salem 403FB-Destination Trailer
2009 F150 4X4 Crew Cab
2006 HD Heritage Softtail
1999 Sweetwater Challenger 30hp (Pontoon)
Mile High
Denver, CO
Posted: 04/07/12 12:49pm Link  |  Print  |  Notify Moderator
Take it to an alignment shop that will handle large trailers - usually over the road truck repair shops. With just 1 tire bad, it very well could be a bent spindle, or even a loose wheel bearing, but you won't know until its checked.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
45Ricochet
North Idaho
Posted: 04/07/12 02:23pm Link  |  Print  |  Notify Moderator
x2
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
phillyg
Front Royal, VA
Posted: 04/07/12 02:46pm Link  |  Print  |  Notify Moderator
X2
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
LostinAZ
At Home
Posted: 04/07/12 02:55pm Link  |  Print  |  Notify Moderator
We had both tires do that on one axle. First thought it might be alignment but upon close inspection determined that the Mission brand tires were developing tread separation. Replacement tires have been on over 10,000 miles with no unusual tire wear issues or similar issues.
* This post was edited 04/07/12 08:42pm by LostinAZ *
wandering1
Posted: 04/07/12 01:52pm Link  |  Print  |  Notify Moderator
X2, dont guess.
HR
