RV.Net Open Roads Forum: Fifth-Wheels: Worn tire question.
 > Worn tire question.
Chippendale
Austin, TX
Posted: 04/07/12 03:31pm Link  |  Print  |  Notify Moderator
LostinAZ wrote:
We had both tires do that on one axle. First thought it might be alignment but upon close inspection determined that the Mission brand tires were developing tread separation. Replacement tires have been on over 10,000 miles with no unuasual tire wear issues or similar issues.
These are the American made Goodyear tires that replaced the Missions that fell apart in the second year. I had a mobile RV repair guy service my wheel bearings last spring, so I am leaning toward taking it to the heavy duty trailer alignment place and have them check for loose wheel bearings. The tire seems to be straight, as compared to the tire in front of it, so I don't think anything is bent, at least I hope not.
Thanks everyone for your opinions.
morley
British Columbia
Posted: 04/07/12 03:49pm Link  |  Print  |  Notify Moderator
We had the exact same problem. One tire only, rear drivers side inside of tire wear only.
Took it to the local alignment shop and the axle was bent.
After the straightening we do not seem to have the problem any longer.
The cost was cheap. $125.00. We mounted our spare on the area that the axle was straightened and that way we can see if it will happen again.
A possible cause as pointed out at the alignment shop is that this is the way that most of us back up either into a campsite or at home and a lot of pressure is put on that back drivers side tire. Could be maybe???
Hope that this helps.
2008 Topaz F254SS 26 ft.
2009 Chevy Silverado, 2500HD, Duramax, Allison Tranny, 4x4, EC
Honda EUi2000
dbbls
Missouri
Posted: 04/07/12 05:00pm Link  |  Print  |  Notify Moderator
First, I would carefully look at all the suspension parts. Replace anything that is worn. This may correct the problem.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
RandACampin
Kathleen, Georgia
Posted: 04/07/12 05:44pm Link  |  Print  |  Notify Moderator
Alignment no doubt.
LostinAZ
At Home
Posted: 04/07/12 07:36pm Link  |  Print  |  Notify Moderator
You don't need to go to the expense of taking the RV to a HD alignement place to determine if the wheel bearings are loose. Just carefully jack up each wheel(make sure you know how to do this properly) so that it is completely free from any weight on it. Then try to tilt the wheel top vs bottom or side vs side. If there is any play noticeable at all the wheel bearings are too loose.
AZ T&T
Mesa, AZ
Posted: 04/07/12 07:57pm Link  |  Print  |  Notify Moderator
Had the same tire wear and it was a bent axle.
AZ T&T
2012 Jayco Eagle Super Lite 29.5RKS
2011 Chevy 2500 HD 4x4 Duramax
B&W Companion Hitch - Firestone Ride-Rite Air Bags
Honda EU2000i Generator
CactusJohn
Scottsdale, AZ
Posted: 04/07/12 11:10pm Link  |  Print  |  Notify Moderator
I had excessive wear on the outside of my front curb-side tire. Turned out it was a bent axle spindle. The axle shop told me that a bent spindle usually causes wear on the inside, so mine was an exception to the general rule. They also said my bent spindle was probably caused by some sort of impact. I didn't remember hitting anything, including a pothole, but we don't always feel those things unless the TV hits it also.
2007 Ameri-Camp (RIP) Summit Ridge SF27RK 5er
2012 F250 Lariat SuperCab, 6.7L PSD
Reese 16K Kwik-Slide with BedSaver
Howaboutnow
AZ
Posted: 04/10/12 10:19pm Link  |  Print  |  Notify Moderator
What brand of tire is this? A tire beginning to fail can create this wear pattern.
