RV.Net Open Roads Forum: Class C Motorhomes: 2010 Freelander E-450 Fuel Filter
 > 2010 Freelander E-450 Fuel Filter
flybuddy
Fort Myers
Posted: 04/07/12 01:42pm Link  |  Print  |  Notify Moderator
9000 miles and just as I was putting it away last week check engine light came on. I had just fueled a few miles prior and noticed after that the the idle was a little rough. Figured I might have gotten some water or crud in gas. Pulled the code today and it was P00171 which shows as "left bank lean mixture". Makes sense with bad fuel so I decided to change fuel filter. After tracing the fuel lines under the unit from engine to gas tank 10 times I've come to the conclusion that there is no fuel filter (unless it's in the fuel tank). Does anyone know if that's the case?? I though most E450s had fuel filter on frame rail under drivers seat---not there. Anyhow I changed air filter and dropped into fuel tank 2 cans of Sea Foam. Any other suggestions appreciated.
j-d
Sunny Florida USA
Posted: 04/07/12 02:08pm Link  |  Print  |  Notify Moderator
Inside the C-Channel of the driver side frame rail, under the cab area. Our 2002 chassis has an exhaust heat shield near the fuel filter. Yours, on a 2009-or-10 chassis, wonder if they moved it...
This Closed Thread talks about where it is, what tools, how to change it.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
knobhill24
Upper Michigan
Posted: 04/07/12 07:14pm Link  |  Print  |  Notify Moderator
My 2011 E-450 only has a filter on the inlet to the tank that is suppose to have last a life time ever how long that is. I do not know which year they stopped putting in the in line filter.
flybuddy
Fort Myers
Posted: 04/07/12 07:24pm Link  |  Print  |  Notify Moderator
Thx, guess 2010 must be the same. Hard to find any info online. Vehicle manufacturers never learn. In the tank fuel socks, in tank filters and combo fuel pump filters have always been a headache somewhere down the road.
RGordon
Atoka, TN/North Ft Myers, FL
Posted: 04/07/12 07:31pm Link  |  Print  |  Notify Moderator
It is probably the MAF (mass air flow) sensor dirty or might check air filter. The O2 sensor on number 1 bank (number 1 cylinder side) that brings in the code you stated. Would think if fuel filter was dirty it would be affecting more than left bank misture lean condition.
Ron & Libby Gordon
07 Ford F350 Dually Tow Boss Diesel
07 Mobile Suites 38RL3 #3698
02 Winnebago Adventurer 35U V10 (Former RV)
Learn from yesterday, live for today, hope for tomorrow
flybuddy
Fort Myers
Posted: 04/08/12 05:50am Link  |  Print  |  Notify Moderator
Thx, the air filter was surprisingly filthy for less than 10k, replaced it. I'll check the MAF sensor also.
j-d
Sunny Florida USA
Posted: 04/08/12 12:05pm Link  |  Print  |  Notify Moderator
So then I take it the only fitering is when fuel is being dispensed from nozzle into the vehicle...? That really doesn't seem acceptable.
wolfe10
Posted: 04/08/12 03:27pm Link  |  Print  |  Notify Moderator
No, as with all fuel filters, it is between the vehicle fuel tank and engine. It can be before or after the fuel pump, depending on application.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
Dusty R
Charlotte Michigan 48813
Posted: 04/08/12 04:29pm Link  |  Print  |  Notify Moderator
When our '02-'03 was new the check engine light came on because we didn't get the gas cap on quite right.
