RV.Net Open Roads Forum: Class A Motorhomes: 460 Ford in Class A dies
 > 460 Ford in Class A dies
yellowdog101
Posted: 04/07/12 04:12pm Link  |  Print  |  Notify Moderator
I have a 1989 29' Georgie Boy Cruisemaster with John Deere chassis and 460 Ford carberated gas motor. I got it last summer and drove it 550 miles before the motor blew while I was still on the way home. It had 72,000 miles on it and ran great until it blew 80 miles from home.
Now I have a new rebuilt motor and it has a problem. The first day (last Thursday) I drove in town and put about 10 miles on it. It ran good but did pop (like a back fire) once. Yesterday we were load and took off the the lake 60 miles away for a test drive and weekend of camping. 8 miles from home the motor poped once or twice then died. We got pulled back to town and to the truck mechanic who installed the rebuilt motor. He got it running but didn't know what he did. (We did put a new coil on it while we were stalled 8 miles out.)
We took off for the lake again and made it about 20 miles. It died again and AAA pulled us home. Last night after it was cooled of it still wouldn't start but this morning it starts right up. The temp was running about 218 acording to the gauge but I don't think it is heat related because it won't start sometimes after setting and cooling down. Looks like several people have messed with wiring as there are "rats nests" everywhere. Even wires going to the coil have been spliced.
The 550 miles I drove with the old motor it ran 220 degrees on the gauge,
I welcome any ideas of where to look for a solution to the problem.
thanks in advance. First MH and really looking forward to being able to use it.
Ronnie
sunkatcher
Fulltimer
Posted: 04/07/12 04:40pm Link  |  Print  |  Notify Moderator
Have you had the FUEL presure checked. My old 460 would "POP" just before my pump went bad.
Ron
masa4u.com
Jagtech
Sunny Southern Alberta, Canada
Posted: 04/07/12 06:01pm Link  |  Print  |  Notify Moderator
There are so many things that can cause this, including those mentioned above. Don't forget to check if the gas tank vent is plugged, or the wrong gas cap, which will cause a vacuum to build in the tank as you use fuel from it. After a short time, the fuel pump can't overcome the vacuum in the tank, so the motor will quit. Remove the gas cap and see if that allows it to restart right away.
1998 Triple E F53 with 460 Ford
1995 Jeep Wrangler toad
yellowdog101
Posted: 04/07/12 07:44pm Link  |  Print  |  Notify Moderator
Home Skillet wrote:
More than likely, the ignition module is bad.
Usually when it won't start you can pour water on the module to cool it off enough to get it running.
I will try to find the ignition module. There is nothing coming out of the coil when it won't start. Then all of a sudden it works.
I had lots of gas coming out of the jets looking through the carb wth the air cleaner off. Of course that was sitting still and after sitting a while. I will keep the fuel and gas cap in mind.
I am going to find and replace the module. I am going to replace disturbutor cap and rotor too just because.
If I replace all of that and it works, I really won't know what the problem was BUT it will work and that stuff is all new.
thanks again....
Home Skillet
Pearland Texas
Posted: 04/07/12 08:02pm Link  |  Print  |  Notify Moderator
Here's the ignition module. Look on the back for any signs of bubbling in the silicone sealer.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,SmarTire,Bilstein Shocks,Trans temp guage,Lowrace iWAY
Home Skillet
Pearland Texas
Posted: 04/07/12 05:42pm Link  |  Print  |  Notify Moderator
yellowdog101
Posted: 04/07/12 08:19pm Link  |  Print  |  Notify Moderator
thank you, I'll look in the morning. I think I bought some ignition parts for one of my Studebakers from a guy in Pearland TX.... :-)
Jerry B
Lake of the Ozarks
Posted: 04/07/12 08:22pm Link  |  Print  |  Notify Moderator
Hey Dog, how did they pull the motor out of your RV? Where did you get the rebuild? Good luck with your problem. Thanks.
Jerry B
Mobile Suites 36TK3
yellowdog101
Posted: 04/07/12 08:31pm Link  |  Print  |  Notify Moderator
A diesel truck shop did the swap. They took the front axle and wheels and tires out and took the motor out of the bottom. Labor was $1600 including $75 starter and about $75 worth of gaskets that the rebuilder supplied but where wrong. I think the rebuilder was "rebuilders.com" but not recommended. I paid $2550 and found a place on eBay same price and perfect feedback. I was told mine would be shipped right away and it took 5 weeks to ship.
good luck with yours
ScottG
Bothell Wa.
Posted: 04/07/12 08:53pm Link  |  Print  |  Notify Moderator
I would bet money on the ign module. There were so many problems with them that a Ca. judge tried to force a recall (bringing to question, just how much authority he has).
Scott, Grace and Wesly
H0NDA eu2000i
