jbrowning
Colorado Springs Co.
Hello everyone, one my 1969 Coachmen trailer I have no 12 volt lights inside but I have my 12 volt porch light. These are all grouped together with the positive coming off of the battery into the trailer. Could there be a fuse or a breaker in the breaker box? Even though I thought the breaker box was only for the 110v system. And yes the battery is charged and the ground is good.
Thank you
Jim
edited 04/07/12 08:14pm by jbrowning *
jasult
Central NJ
Yes there has to be a 12 volt fuse or several 12 volt fuses someplace.
In my 5th wheel trailer I have a circuit breaker panel for 110 plus a fuse panel for 12 volt
Jim & Georgeanne + Lucie the beagle
"excavator" on the DieselStop.Com
1996 F250 Powerstroke, Baby Swamp injectors,BTS Trans TW Chip,210,000 miles,
1995 Fleetwood Wildness 30 ft 5ver
Our Camping Pics and 5ver Album here
Our Gettysburg trip 2010
Williamsburg, Va
Gene&Ginny
North Kingstown, RI
When I open the door on my converter box it has 120 volt breakers on the left and 12 volt fuses on the right. Many units are similar to that.
Gene and DW Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
Artum Snowbird
Campbell River, B.C., Canada
You need to determine whether the power is getting to the light, and the return is not made, or whether the power is not getting there.
Get a long piece of wire and touch it to the outside of a light socket that the bulb is not working in, and to the negative on the battery. If the light lights, it's the neutral that is faulty... if it doesn't, it's the power.
If you have a meter, even better.
It's a simple test, but one many overlook.
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
jbrowning
Hi, here is what I have for a breaker box. Pretty basic I think. Probably because of how old it is. I don't see anywhere for fuses to be at.
Thanks
Jim
jbrowning
Artum Snowbird wrote: You need to determine whether the power is getting to the light, and the return is not made, or whether the power is not getting there.
When I do this. Do I need to dig around to make contact with the wire that is leading into the light socket? Why I'm asking is because the outside of the light socket is plastic.
Thank you
Jim
garym114
Bluff Dale, Texas
That is your 120v AC breaker box. You have a 12v DC fuse panel somewhere.
Try looking around your converter.
garym114
Bluff Dale, Texas
jbrowning wrote: Artum Snowbird wrote: You need to determine whether the power is getting to the light, and the return is not made, or whether the power is not getting there.
Thank you
Jim
Find your 12v fuses first.
CavemanCharlie
Storden,MN
There must be 12 volt fuses somewhere.
But, I wonder, does a 1969 Trailer have a converter????
jbrowning
CavemanCharlie wrote: There must be 12 volt fuses somewhere.
I honstly don't think this trailer has a converter on it. Any idea of where I would start looking for these fuses at? I am guessing they would be inside the trailer somewhere? I know the fuse off of the battery is good. But there must be more fuses somewhere else?
Thanks
Jim
