RV.Net Open Roads Forum: Need to change out the bathroom fan
 > Need to change out the bathroom fan
Tothill
BC
Posted: 04/07/12 07:25pm Link  |  Print  |  Notify Moderator
Just looking for some tips on changing out the bathroom roof fan.
The original blades (1989), are kaput. I checked locally and we have a few options.
Just replace the fan portion, The motor works, but is noisy and probably will not last more than a couple seasons.
Replace both motor and fan blade. Problem the motor is welded in place and at that point we are looking at $40.00 in parts locally.
Figure out how to ripe out the motor and replace with a 12V computer fan. It would be quieter.
Bite the bullet and buy a Fantastic Fan or other such fan. We already have a Maxx Air cover on the vent. I am not sure of the local cost to buy.
I have limited skills (have replaced household electrical fixtures, but really do not want to pay to have the work done. I know I can easily just replace the fan blades.
Any ideas on how to easily break the weld on the original fan motor?
I will be looking at the stove vent fan too. I am sure it is wearing out as well.
Thanks in advance for any and all help.
rjf7g
Virginia
Posted: 04/07/12 07:29pm Link  |  Print  |  Notify Moderator
I would just replace the fan blades. Wait for the Fantastic Fans to go on sale at PPL or Camping World. You can get them 30 - 50% off if you are patient.
2006 Palomino Puma 27FQ Bunkhouse
2007 Gulfstream Innsbruck 36FRS Park Trailer
kcgaz
Scottsdale, Arizona
Posted: 04/07/12 07:32pm Link  |  Print  |  Notify Moderator
This Blog does a great job of walking you through a step-by-step process of replacing your bathroom fan.
CLICK
God Bless,
Kevin & Tracy
1993 Fleetwood Tioga Arrow, 30', Ford 460...Still on the road!
My Blog
Dutch_12078
Great Sacandaga Lake, NY
Posted: 04/07/12 08:13pm Link  |  Print  |  Notify Moderator
Take a look at Heng's Vortex Retrofit kit. Easy install...
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
Kiwi_too
Western, WA
Posted: 04/07/12 08:52pm Link  |  Print  |  Notify Moderator
x2
for the bathroom.
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
Charltons
Battle Ground, WA
Posted: 04/07/12 09:41pm Link  |  Print  |  Notify Moderator
Kiwi_too wrote:
x2
for the bathroom.
X3....about a 20 minute job....a little quieter, but the airflow is dramatically higher.
2012 Dodge Ram 2500 Crew Cab 4X4 TCD
2012 Keystone Sprinter 311BHS
pdlarson
Billings MT
Posted: 04/07/12 10:01pm Link  |  Print  |  Notify Moderator
X 4 for the Vortex. Quieter, moves more air, worth the cost, problem solved. You won't regret it at all. Put a smile on my face the first time I turned mine on. Not as quiet as a Fantastic on low but waaaaaaay quieter than the stock howler fan.
Billings MT
2006 Suburban 1500 LTZ 6.0L 3.73 gears Curt hitch
2012 Springdale 210BHLWE 25'
Tekonsha Voyager
Golden_HVAC
Fulltime, CA, USA
Posted: 04/08/12 12:24am Link  |  Print  |  Notify Moderator
Install a Fanastic fan. If the motor ever gives you trouble, call the company, they will arrange to send you it's replacement, even if the unit is over 10 years old. Great airflow, fairly quiet on low fan speed, and much more air flow on slow fan speed than the other fan did!
Fred.
gotsmart
Aberdeen, WA
Posted: 04/08/12 01:44am Link  |  Print  |  Notify Moderator
Fred.
ditto. I'd find myself sitting on the toilet and realizing that I should have opened the vent and pressed the plunger-switch to turn the P.O.S. bathroom fan on - by that time it is too late. After about a year of doing that I decided to get this FanTastic Fan with the remote. Now when I forget to open the vent - I grab the remote, press a button - done. Quite possibly the best investment in the MH, yet.
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
SidKaye
Mt Dora Florida, Montreal QC for the Summer
Posted: 04/08/12 07:12am Link  |  Print  |  Notify Moderator
Tothill, replacement blade for an ordinary bathroom vent fan is about $5.00. Easy to replace. There are generally 2 types of splined shaft that they fit. One is round and one is "D" shape. It is important to get the correct one. You just need to remove the old blade by gently prying it off the splined shaft. Once off, check to see if it is round, or IF the hub is intact, check the shape. Most RV parts stores stock the blades. If it is an ordinary vent fan, it is likely a "Ventline" so you can also search the internet for parts.
Sidney
2003 Dodge Ram 3500 SLT,48RE, 4:10,Cummins HO Diesel,Quad Cab,LWB,SRW,PacBrake,Prodigy, X-Monitor Gauges,Line-X,Bedsaver
2002 Excel,Ltd,30RGW,Hughes Autoformer,Honda Eu1000i, ClearSpot 4G+,
http://www.kayepics.com
