RV.Net Open Roads Forum: Toy Haulers: Sound deadening, Dynamat
Search only in Toy Haulers
 > Sound deadening, Dynamat
Jerrybo66
AZ
Posted: 04/07/12 09:07pm Link  |  Print  |  Notify Moderator
This is probably the wrong forum but I need to thank you guys for the recommendation for Dynamat. My Arctic Cat Prowler was so noisy that I almost didn't want to ride it. I was always reluctant to buy Dynamat because of the price, what if it didn't work? Last week I figured, so what, it's only money. I lined the consul/dog box with the product and am thoroughly satisfied. For the first time the noise of the Cat is from the exhaust and not from "surround sound". You guys and your experience are the greatest..
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
ScottG
Bothell Wa.
Posted: 04/07/12 10:45pm Link  |  Print  |  Notify Moderator
So it really made that big of difference? The price has held me back too.
Scott, Grace and Wesly
H0NDA eu2000i
Jerrybo66
AZ
Posted: 04/07/12 11:11pm Link  |  Print  |  Notify Moderator
Here's what I think I've learned. I thought sound waves had to be interrupted and muffled. That is probably true but I didn't know about "stuff" that absorbers the waves and projects them further. (Excluse my ignorance). If the items that are affected by the sound and would normally vibrate to increase the sound is muffled, so is the noise. When our Pit barks, the tubes of the door bell "sings". So is any sound of any noise makes any material vibrate to make more irritating noise. My new theory, keep any material affected to the noise from vibrating, thus preventing further noise. Danamat does this..It's a stick aluminum covering that keeps the applied surfaces from vibrating.. (Please help)
danager
Edmonton Alberta
Posted: 04/08/12 01:13am Link  |  Print  |  Notify Moderator
I was a professional (MECP certified) installer for nearly 12 years, and installed my share of Dynamat. The stuff is great, and you described it well. A lot of items resonate due to sound created around them. This resonance not only transmits sound, those items then create their own noise.
If insulating (isolating) noise, you can use a lot of material, and cover areas completely. If you are just wanting to stop a panel or surface from vibrating, you can use a small amount of Dynamat. I could stop a trunk from buzzing and rattling with 2 square feet of Dynamat.
pulsar
Lewisville, NC
Posted: 04/08/12 05:06am Link  |  Print  |  Notify Moderator
Moved from Forum Technical Support.
MadMav
Colorado Springs, CO
Posted: 04/08/12 06:31am Link  |  Print  |  Notify Moderator
Not sure I understand...you Dynomated your ATV? I've heard of lining the generator compartment, but never an ATV.
Mav
"A fifth wheel trailer is a bi-level towable mobile home."
Jerrybo66
AZ
Posted: 04/08/12 11:07pm Link  |  Print  |  Notify Moderator
Mav
An Arctic Cat Prowler is a Jeep type Atv with two seats separated by a consul and a storage/dump box in the back. . The consul is over the motor. The underneath motor cover is what I covered with the Dynamat Sound Proofing. My Artic Cat 500 is so quiet that I would make no attempt to make it any more quiet....
MadMav
Posted: 04/09/12 06:48am Link  |  Print  |  Notify Moderator
Now I get it. Very good to hear it worked.
Mav
