joebedford
Jasper, Ontario
The yearly migration of snowbirds returning north is well underway - me included. I saw many fifth-wheels on the road and the vast majority of them were being towed by 3/4 ton PUs.
In the past I counseled newbies to get a truck that is rated for their trailer. But based on actual observation, I see that is unnecessary.
I saw a 3/4 ton short box towing a trailer just like mine at 75MPH. I guess the 65MPH rating on the trailer tires really doesn't matter either.
I saw a 3/4 ton squatted down so far that the front wheel looked like they were almost off the ground. He couldn't go over 60 because the trailer was wagging so much. Rear truck tires looked almost flat.
There was another one that compensated for the rear squat with airbags. The bags were pumped up so much that I could see the camber in the front suspension from the weight transfer.
One guy passed me three times but each time I'd see him stopped at the side of the road looking under his trailer. I don't know what that was about but it didn't stop him from doing 80mph.
I go 65mph.
Anyway, you get the idea. I didn't read about any horrific crashes so I guess everybody made it home 'safely'. We can all be thankful for that.
Happy Easter.
2011 Silverado 3500HD LTZ CCLB 6 x Michelin LTX MS2 80 psi
2011 Voltage 3950 6 x Bridgestone Duravis R250 80 psi
2004 H-D VRSCB(mine)
1996 / 2007 H-D / DFT FLHTCUI Trike(hers)
2004 Thor Dutchman 35SRV traded
2004 Dodge Ram 3500 5.9 CTD traded
whporwil
Minnesota
Remember what ever the brand they all have the same motor so yes they can tow just as well. Personally I traded my 08 F350 swr for a 08 F450.
fordsooperdooty
California has a 55 mph speed limit for trailer towing. I rarely exceed that.
I'm on vacation.
mowermech
Billings, MT
"I guess the 65MPH rating on the trailer tires really doesn't matter either."
Why do you think they had trailer tires (ST)?
Perhaps they, like many folks do, put LT tires on their trailer.
I would.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
old guy
Oregon (pronounced Or e gun)
you saw snow birds doing 75 MPH on the road north. You must not be on the same road I was on because most were doing 45 in a 75 zone. all were hazardous to the health of all on the road behind them. I guess they drive 75 going down and 45 going home.
dubdub07
Colorado Springs
I must apologize that I didn't get my counseling from you when I started. That is, I guess, why I am pulling my 36ft FW with my 2500 Dodge Ram 6.7CTD. And yes, it does have airbags.
I have never noticed an E rated tire looking almost flat (they are E rated on 3500s also) or the camber of the front of a 2500 out of whack, seeing how a 2500s front suspension is identical to the 3500.
I have driven 75mph with my FW in tow. Normally I am about 70mph, but occasionally I will speed up a bit.
Love your 3500. Don't hate my 2500; it is nearly identical to yours.
2013 Fleetwood Discovery 40G
TOADS: 2012 Jeep JK Rubicon, 2012 Durango Citadel
2010 Harley Heritage Softail....American STEEL = American profits.
steelpony5555
Copperas Cove Texas
Some people just gotta pizz and moan or that ain't happy......
06 Montana 3000RK
07 Dodge 3500 Dually Sport 6.7 Diesel
07 Pearl White Ultra Classic (My new Baby)
10 Chrysler 300 Touring
Texas Boomers---Stop by for a Margie some time!
sirdrakejr
Las Vegas, Nevada
Moved from 5th wheels to tow vehicles.
Frank
LostinAZ
At Home
"There was another one that compensated for the rear squat with airbags. The bags were pumped up so much that I could see the camber in the front suspension from the weight transfer."
I have rear airbags on my F250 and they only raise the rear. Not sure I understand what is being said here.
I too hope that it is understood that in many cases the only difference between a 3/4 ton SRW truck and a 1 ton SRW truck is slightly heavier rear springs on the One Ton SRW. Same engine, same front axle, same transmission, same rear axle rating, same shocks, same E rated tires. A 3/4 ton truck is not a Tonka truck and a 1 ton truck is not a Kenworth.
jerem0621
Sequatchie, TN
No half tons pulling fivers or heavy TT?
Come on now, was it really that bad?
My dad tows a 14k GVWR Fiver with his 03 Dodge 2500 without airbags (Cummins), Tows great!
Ironic that the 3/4 ton guys are taking a beating on this thread.
1 ton guys beat up on 3/4 ton and half tonners
3/4 toners tell the one toners that they are ok and the half tonners that they are NOT ok.
Half ton guys, well, we just run what we brung.
Pulled my trailer tonight at 65, could have ran 75, how can a little ole 5.4 do that? Same as the 3/4 ton guys pull big fivers,
we hitch and go.
Thanks!
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
