Hannibal
Gas Station
Looks like the 8.1L snatched the jaws right out of that hitch! Training wheels gave him too much traction!
'10 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
'07 KZ Jag 28JFSS.
jerem0621
Sequatchie, TN
4x4ord wrote:
Now maybe had he been towing with a 3/4 ton that wouldn't have happened.
Serious question:
Would this have been possible with a ball mount vs a king pin. Specifically, I am talking about a gooseneck or Andersen Ultimate Fifth Wheel connection.
Thanks!
Jeremiah
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
recycler
michigan
when i was a kid guy went by thought his 82 up z-28 could tow anything..to this day can't figure what shop would put a 2in receiver hitch on a camaro had boat big as a 5th wheel on it with load leveling hitch talk about low rider
1968 franklin 11fk
back to my 93 cummins
RobertRyan
Australia
SoCalDesertRider wrote: You and I must be the only 2 people in California who even remotely try to abide by the 55mph trailer towing speed limit. I go 55-60. I haven't seen a trailer doing 55mph in a long time, unless the truck just simply couldn't climb the hill any faster. Most are doing 65-75 like everybody else, including the 'professional' semi truck drivers.
Roughly 60mph , but others stick it on the 70mph(110kph) speed limit here
SoCalDesertRider
SanDiego, CA, USA
recycler wrote: when i was a kid guy went by thought his 82 up z-28 could tow anything..to this day can't figure what shop would put a 2in receiver hitch on a camaro  had boat big as a 5th wheel on it with load leveling hitch talk about low rider  As unbelievable as it may sound, there's a guy here on the forum who, for real, has been working on installing a 5th wheel hitch in the back of an 80's or early 90's model Camaro or Firebird, I forget which. He has pictures of his project partly completed.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
captainjohn2008
Ontario
Whoa, there 250/2500 owners, joebedford was just making his observations on these trucks/trailer combos. He never mentioned his was better/stronger/faster/bigger etc. Just his daily observations of a roadtrip. That,s all. This forum seems to be taken over by 250\2500 owners who seem to have the need to justify their purchase of their trucks of choice. Can't we just all get along? Let,s just be safe out there.
SoCalDesertRider
SanDiego, CA, USA
From my observations, I see plenty of Toyotas and Rangers loaded down with loads that should have been in an F150/1500. I see plenty of F150/1500's loaded down with loads that should have been in an F250/2500. I see plenty of F250/2500's loaded down with loads that should have been in an F350/3500. I see plenty of single rear wheel one-tons loaded with loads that should have been in a dually. And I see 1-ton duallys with loads that should have been in a class 4 commercial truck.
So it's not just F250/2500 guys that are guilty of trying to do more with the truck than it was made to do. Just about anyone who has owned trucks has been guilty of it at one time and another.
Rick MC
Long Island
My F250 with the 40 footer. I Never drive over 60, as soon as I see it over I slow down, even with a bigger truck I would be the same way!
2008 F350 Lariat DRW 6.4 PSD Super Duty 4.10 Rear
2011 Komfort 3530 FBH
Q5 Curt 20K Slider
2008 F250 Lariat Super Duty Firestone Air Ride Bags {sold}
rightlaneonly
CA..
With all said and done, remember the "long long trailer. What was that, a "53" Merc. convertable? Actually they really did pull some mighty big trailers on the bumper of those old tanks !
Leroy & Jane
2009 Jeep Wrangler Unlimited X and a 2004 Aliner Sportliner.
I wanna go where I haven't been,
but still wanna see what I've seen again.
57 Panhead
Central Valley Calif.
solman wrote: Do the 350's and the 250's get the same tires as far as weight carrying go? I know the size is different.
If so it seems that air bags could make a 250 into a 350.
The F350 comes with 18" wheels with a tire that is rated at 3640 lbs and a 20" wheel but I don't know the weight rating of the 20" tires. My 2007 F250 had a 17" wheel that had a tire wt rating of 3195 lbs, so yes, the F350 has tires that will bear more weight. This is on a SRW truck of course.
I just put a set of F350 alloy wheels with brand new 275X70R 18 which in combination with the air bags give me the same weight capability as the F350. WEIGHT POLICE BUTT OUT!!!!
Steve
Retired Teamster
2012 Jayco Eagle Superlite 31.5RLTS
07 F250 PowerStroke
U Y B
