RV.Net Open Roads Forum: Class A Motorhomes: HOT front AC breaker
 > HOT front AC breaker
thestarfinder
Mount Gretna Pa.
Posted: 04/08/12 03:42am Link  |  Print  |  Notify Moderator
AC breaker is hot and has tripped a few times(I'm not running the AC now)....I replaced breaker and the back where it is in the bar, on the old one was cracked and deteriorated from the extra heat.....Rear AC is fine.....Breaker is 20 amp.....Any thoughts on the heat? Thanks, Tom
Exist Responsibly.........
Doug and Cassi Glass
Clifton Forge, VA
Posted: 04/08/12 04:08am Link  |  Print  |  Notify Moderator
Was a wire loose? That can cause them to overheat. Age can also be a factor. Rig info would help. Somebody with the same rig might jump in.
thestarfinder
Mount Gretna Pa.
Posted: 04/08/12 04:16am Link  |  Print  |  Notify Moderator
The rig is a 2001 Monaco Windsor.......
farmer_boots
Weirsdale, Fl
Posted: 04/08/12 04:29am Link  |  Print  |  Notify Moderator
If no loose wires or corrosion I would get an amp meter and see what's going on in that circuit.
2006 Monaco Diplomat
J Walker
Oakton, Va
Posted: 04/08/12 04:53am Link  |  Print  |  Notify Moderator
You replaced the breaker and you say the new breaker still heats up? As already stated, make sure the connections are tight. The next thing to check is the air conditioner. It may be drawing too much current. A clamp on current meter can help there.
Jim Walker
2000 34' Damon Ultrasport DP
2009 Malibu
Brake Buddy
Wills250psd
walnutcove NC
Posted: 04/08/12 05:40am Link  |  Print  |  Notify Moderator
maybe the compressor is going out or the fan is sticking. remove the shroud and take a look around.
eHoefler
ozark mountains
Posted: 04/08/12 06:46am Link  |  Print  |  Notify Moderator
Most likely the compressor is about to go, it is the high draw item in this setup. Like said above, pull the shroud and use an amp probe to check the draw from the compressor. The compressor will be hot as well if it is the culprit.
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
PandK
Greenville, SC
Posted: 04/08/12 07:49am Link  |  Print  |  Notify Moderator
Agree with checking the amp draw. I "assume" there were no obvious issues with the breaker compartment itself ie corrosion or signs of arching where the breaker connects to the breaker box. You could swap the wires going to the A/C units (front breaker feeding the rear unit and visa versa) to see if the "other" breaker gets hot also. If the "other" breaker gets hot it is a good indication of a compressor issue. Need to follow the standard electrical safety procedures (power OFF) especially when checking the inside of the breaker box.
Paul and Karla
Cinnamon & Pequeno - Spoiled Rotten Chihauhuas
2004 Rexhall Rexair DP3955
2013 Chevy Traverse
Wherever I happen to park
Posted: 04/08/12 01:39pm Link  |  Print  |  Notify Moderator
Loose wire, Old breaker, Defective Breaker. LOW VOLTAGE operation of Air Conditioner and..
This is a biggie
Pop the top on the air conditioner (Remove the shroud and the covers inside it) and clean the coils, both Evaporator (inside/cold coils) and Condenser (Outside/hot coils) also anything else you think would benefit from a good cleaning.
rvrepairnut
bc
Posted: 04/08/12 01:58pm Link  |  Print  |  Notify Moderator
sounds like the AC is drawing too much power
