ralphnjoann
Canon City, CO
mike-uswest wrote: My understanding with these, is that if you put in too much, you will also get your brakes well lubed.
Mike Not true. If your grease seals are good, the excess grease will come out at the outside bearing.
lightfoot
Cary, Illinois
Just had mine done by a professional trailer company and they say the hardest thing about the ez lube job is taking the wheels off if there is a hub cap on the wheels. They have never had a problem with getting greese on the breaks with the ez lube system and they use a commercial lube system. Do the job right and you will only need to remove the hubs every 5 years to do a hand pack job said the tech at the trailer shop.
USN EN2 (RET)
2012 Ford F250 SC, 6.7L Turbo Diesel
2011 Voltage 3200
'94 Honda GL1500
'00 Yamaha Venture
MudChucker
Niverville Manitoba
Duramax1 wrote: You must be using a very large hand pump if you can put a tube of grease through with only 10 pumps.
Lol...I can se that... I meant to say, 10 pumps and turn the wheel and so on, indicating as well that you will pump in an entire tube, 10 pumps at a time before turning the wheel it might take about a hundred pumps in total to squeeze a tune through
2005 PILGRIM 274RL 5SS
2007 GMC Sierra 2500HD SLT 6.0
MudChucker
Niverville Manitoba
Mike
Not true at all.
The system is well designed...
Like I said above, the grease comes out of the bearing towards you and you catch it in an old mug as it falls out...
MudChucker
Niverville Manitoba
Look at the arrows indicating the flow of grease.
steelpony5555
Copperas Cove Texas
I don't believe it's really necessary to pump till all the old grease comes out. Just pump till you get some grease to ooze out and that way it's full... If you are pumping till all te old grease comes out you are running the risk of blowing out the rear seal. When you do pump in the new grease pump it very slowly.
06 Montana 3000RK
07 Dodge 3500 Dually Sport 6.7 Diesel
07 Pearl White Ultra Classic (My new Baby)
10 Chrysler 300 Touring
Texas Boomers---Stop by for a Margie some time!
MudChucker
Niverville Manitoba
I have been pumping a tube per hub or as long as I have had trailers with ez lube hubs...never once have I had grease pass the inner seal, even on seals that were toast.
As per the manufacturers specification, pump grease till you see new grease.
