RV.Net Open Roads Forum: RVing with Disabilities and General Health Issues: Blood Thinner
Search only in RVing with Disabilities and Ge...
Tazymae
Kentucky
Posted: 04/08/12 05:49am Link  |  Print  |  Notify Moderator
My husband is on warfarin and he needs is blood checked every two weeks. We are leaving tomorrow for about 4 weeks. Is there any place he can go to get his blood checked and then I can call his doctor with the results?? I know this is short notice and I should have taken care of this sooner. Any help is appreciated
Scottiemom
South Dakota/Indiana
Posted: 04/08/12 06:01am Link  |  Print  |  Notify Moderator
When DH was on warfarin, we used Lab Corp exclusively. You will need to get some prescriptions for the specific test your doctor requires. We got those every year from our doctor. He would write out as many as we thought we needed. When it was time for a blood test, we would look up Lab Corp on line and find one near us. We would walk in, present his prescription and insurance info and they would draw the blood. They send the results to the doctor. You will need the doctor's fax number. We did this for almost six years as we full time. It worked well.
Dale
Dale Pace
Wife to Terry (Teacher's Pet)
Mom to Scottish Terrier, Duchess
2006 Tiffin Phaeton 40'(Phaeton Place)
2014 Ford Flex
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltiming since 2005
http://www.skoolzoutforever.blogspot.com/
Where are we?
CREATO
Beautiful Harvey N.D.
Posted: 04/08/12 06:25am Link  |  Print  |  Notify Moderator
I have been on coumadin since I was eighteen I only test monthly. As stated you will need prescriptions from a dockter you can go to most any clinic or hospital to have a protime done. You then wil want them to send the results to your dockter this can be done via e[emoticon]ail or fax, the Doc. can then e[emoticon]ail or fax your prescription to a pharmacy you want to use.
Dont know why the little faces are coming up on email
I dont rent out space in my brain
Tazymae
Kentucky
Posted: 04/08/12 06:28am Link  |  Print  |  Notify Moderator
Thank you all so much...it is [emoticon] getting old.....
skipnchar
Topeka or somewhere else
Posted: 04/08/12 06:39am Link  |  Print  |  Notify Moderator
Depending on your insurance and who they cover, there are many places you could go. I'd call them first and get a referral or at least a referral letter. Often times they will not release the results to YOU (the patient) but may insist that they call your coagulation therapist himself. Getting that referral letter from him will speed things up a whole lot and simplify insurance matters at lot.
Note that there can be a HUGE difference in how different organizations handle reporting INR. Some have a simple stick mechanism like a blood glucose kit and give you immediate results (my regular doctors do this) and others I've found have to actually draw a vial of blood and send it to a lab for processing which can take up to a week to get the results. Your anti coagulation theropist can probably point you to the most convenient place in the area you're heading for and save a bunch of hit and miss results. I would also recommend you KNOW what your protimes are supposed to be in case there is a significant wait to get results. Also get a contact number from the organization you use because I've found more cases than not, where what you ask them to do is far different than what happens and you need to be prepared to get in touch when your doctors don't receive the results you were promised they'd get.
Good luck / Skip
larry barnhart
wenatchee. wa usa
Posted: 04/08/12 10:11am Link  |  Print  |  Notify Moderator
My wife checks her blood and calls in the results. If it is low or high the message gets to the heart doc and his coumadin girl calls us to change the dose.
chevman.
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
RamTX
Houston Area
Posted: 04/08/12 11:36am Link  |  Print  |  Notify Moderator
I've taken warfarin for years now. Recently, Quest Labs has apparently started entering prescriptions into a computer database which is accessible to Quest labs in various locations so that you can go to any Quest Lab and get your Pt test. I do not know if this is a nation way system or not. My doctor sends them a standing order for six months at a time. I also know that some doctors can directly submit an order for lab tests directly into the Labcorp system. I would check both labs to see if your doctor can just submit a standing order to either Quest or Labcorp that could be used nation-wide.
2005 Dodge 2500 CTD ShortBed Quad Cab
08 Jayco Eagle Superlite 31.5FBHS
Line X
Superglide Hitch
Prodigy Brake Controller
Retired Wileys
Lake Jackson, Tx USA
Posted: 04/08/12 02:13pm Link  |  Print  |  Notify Moderator
My doc changed me to Pradaxa and it does not require monthly blood draws. I love it.
Herschal & Pam Wiley
2003 2500HD Crewcab Chevy
26H 2000 Prowler LS w/slide
bsinmich
Holland, MI
Posted: 04/08/12 04:10pm Link  |  Print  |  Notify Moderator
Have you looked at the alternative?
As a Christiian I do have an alternative but I still enjoy the Grandchildren and Great Grandchildren here on earth.
1975 GMC Eleganza II & 1995 Roadtrek Versatile. Both old enough to vote and drink (gas)
sh410
Northwest
Posted: 04/08/12 04:43pm Link  |  Print  |  Notify Moderator
the e(colon)mail = (colon)m = [emoticon] emoticon
try either email, used most commonly, or e-mail
