I have a very steep downhill driveway, with a small turn-around area near the house. I can get the FW turned around, but it takes about 15 minutes of back and forward. I'm wondering if it's possible to back the rig down the driveway instead. I would not have a problem steering down; just concerned about braking. Are electric trailer brakes as effective in reverse? Will the 8400lb trailer overcome the braking of the 5600lb tow vehicle and start pulling me downhill? I suppose I could put the TV in 4WD. I'm concerned because once I start backing down, I'm really committed.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
I,ve backed a MH and a boat down some realy steep boat ramps. never a problem . remember slow and easy.some of those ramps are unbleavable steep.and long.
Yes electric brakes work in reverse the same as going forward just like the brakes on your truck. Mine have always worked just as good in reverse. It depends on you controlling the trailer in reverse.
I'm no expert, but I think you nailed it with your 4 wheel drive, low range.
Why not try it somewhere else where you can put another tow line between your truck and the truck in front, and just tell him to keep it loose unless you beep your horn.
Will four braking wheels be enough to contain that weight on a slippery road surface? Certainly rain, frost, or snow will put a whole new set of problems out there.
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
Electric brakes are usually NOT nearly as effective going backwards. Your truck brakes should be able to handle stopping the rig, just not as quickly as usual, but you wouldn't be going fast so shouldn't be an issue. Biggest concern I'd have is if the engine would quit and leave you with no power brakes.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR - 2004 F-150 HD (Traded after 80,000 towing miles) 2007 Rockwood 8314SS 34' travel trailer
Artum Snowbird wrote: I'm no expert, but I think you nailed it with your 4 wheel drive, low range.
This would be a good idea for the first time, just to be safe. If you've got enough people to help, you can also have a person on each side with a wheel chock, to toss behind the trailer tire, if there is a problem.
Once you know for sure that the rig can be moved safely, you won't need all the extra safety help (tow cable or chocks) the next time....unless you want them?
Good luck
Bill & Claudia / DD Jenn / DS Chris / GS MJ Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293 The Pets
I have to back my trailers down a very steep driveway and turn 90* at the bottom then back across the side hill and around a couple big trees to the parking area for the trailers. This is all dirt, except the narrow asphalt driveway with dirt shoulders. The asphalt is usually covered with loose sandy dirt that the rain washes onto the driveway, so traction can be a bit sketchy.
Sometimes the trailer will try to drag the truck's front end a bit when I have the front tires turned sharp and one tire is fully on the dirt and the other on the dirty pavement. Using 4wd helps a little. Creeping along very slowly helps the most. Letting it get going too fast and then trying to stop and turn and same time doesn't work out so great.
Opposite problem, 1/8th of a mile up a steep grade, lined closly with large trees. My wife, the artist, doesn't like straight lines. So when we were building the house she rode on the bulldozer to make sure he made a serpentine cut for the driveway. Then we decided to take up camping. First time took me about an hour...
Bob & Lynn
3 Hua's and Memories of the late, great Zoe, the camping Chow
2013 Open Range 424RLS, Hensley TS-3 Hitch
4-6v golf cart batteries & 2 Honda EU2000i
06' Chevy 3500, dually, crew, Duramax/Allison
