RV.Net Open Roads Forum: Fifth-Wheels: Backing Up Going Down a Steep Hill????
 > Backing Up Going Down a Steep Hill????
phillyg
Front Royal, VA
Posted: 04/08/12 07:23am Link  |  Print  |  Notify Moderator
I have a very steep downhill driveway, with a small turn-around area near the house. I can get the FW turned around, but it takes about 15 minutes of back and forward. I'm wondering if it's possible to back the rig down the driveway instead. I would not have a problem steering down; just concerned about braking. Are electric trailer brakes as effective in reverse? Will the 8400lb trailer overcome the braking of the 5600lb tow vehicle and start pulling me downhill? I suppose I could put the TV in 4WD. I'm concerned because once I start backing down, I'm really committed.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
midnightsadie
ohio
Posted: 04/08/12 07:43am Link  |  Print  |  Notify Moderator
I,ve backed a MH and a boat down some realy steep boat ramps. never a problem . remember slow and easy.some of those ramps are unbleavable steep.and long.
Artum Snowbird
Campbell River, B.C., Canada
Posted: 04/08/12 07:45am Link  |  Print  |  Notify Moderator
I'm no expert, but I think you nailed it with your 4 wheel drive, low range.
Why not try it somewhere else where you can put another tow line between your truck and the truck in front, and just tell him to keep it loose unless you beep your horn.
Will four braking wheels be enough to contain that weight on a slippery road surface? Certainly rain, frost, or snow will put a whole new set of problems out there.
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
skipnchar
Topeka or somewhere else
Posted: 04/08/12 07:52am Link  |  Print  |  Notify Moderator
Electric brakes are usually NOT nearly as effective going backwards. Your truck brakes should be able to handle stopping the rig, just not as quickly as usual, but you wouldn't be going fast so shouldn't be an issue. Biggest concern I'd have is if the engine would quit and leave you with no power brakes.
wandering1
Posted: 04/08/12 08:14am Link  |  Print  |  Notify Moderator
Yes electric brakes work in reverse the same as going forward just like the brakes on your truck. Mine have always worked just as good in reverse. It depends on you controlling the trailer in reverse.
HR
PapPappy
Wilmington, NC
Posted: 04/08/12 08:30am Link  |  Print  |  Notify Moderator
This would be a good idea for the first time, just to be safe. If you've got enough people to help, you can also have a person on each side with a wheel chock, to toss behind the trailer tire, if there is a problem.
Once you know for sure that the rig can be moved safely, you won't need all the extra safety help (tow cable or chocks) the next time....unless you want them?
Good luck
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
3 dog nights
Central, Virginia USA
Posted: 04/08/12 08:39am Link  |  Print  |  Notify Moderator
Opposite problem, 1/8th of a mile up a steep grade, lined closly with large trees. My wife, the artist, doesn't like straight lines. So when we were building the house she rode on the bulldozer to make sure he made a serpentine cut for the driveway. Then we decided to take up camping. First time took me about an hour...
Bob & Lynn
3 Hua's and Memories of the late, great Zoe, the camping Chow
2013 Open Range 424RLS, Hensley TS-3 Hitch
4-6v golf cart batteries & 2 Honda EU2000i
06' Chevy 3500, dually, crew, Duramax/Allison
jasult
Central NJ
Posted: 04/08/12 08:42am Link  |  Print  |  Notify Moderator
4x4 low range at idle and you will be fine
start slow and dont throttle
Jim & Georgeanne + Lucie the beagle
"excavator" on the DieselStop.Com
1996 F250 Powerstroke, Baby Swamp injectors,BTS Trans TW Chip,210,000 miles,
1995 Fleetwood Wildness 30 ft 5ver
Our Camping Pics and 5ver Album here
Our Gettysburg trip 2010
Williamsburg, Va
eye8Ubutler
Maritime Provinces
Posted: 04/08/12 09:21am Link  |  Print  |  Notify Moderator
X2 and I have a 200ft driveway in the same situation, at the bottom I make changes to 4x4 LOW at around 3 mph.
Chevrolet Silverado 1500 LTZ 2007 (new shape)
4x4 Crew Cab VORTEC MAX (L76) 6.0L V8 4L70E 4.10 axle
factory NHT Max Trailering Package.
2010 Coachmen Freedom Express 280 RLS
"...a Waldorf Salad?, sorry we are fresh out of Waldorfs!".......BASIL FAWLTY.
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/08/12 10:34am Link  |  Print  |  Notify Moderator
I have to back my trailers down a very steep driveway and turn 90* at the bottom then back across the side hill and around a couple big trees to the parking area for the trailers. This is all dirt, except the narrow asphalt driveway with dirt shoulders. The asphalt is usually covered with loose sandy dirt that the rain washes onto the driveway, so traction can be a bit sketchy.
Sometimes the trailer will try to drag the truck's front end a bit when I have the front tires turned sharp and one tire is fully on the dirt and the other on the dirty pavement. Using 4wd helps a little. Creeping along very slowly helps the most. Letting it get going too fast and then trying to stop and turn and same time doesn't work out so great.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
