RV.Net Open Roads Forum: Tech Issues: Water pump
 > Water pump
Latner
Indiana
Posted: 04/08/12 10:20am Link  |  Print  |  Notify Moderator
I need some input on water pumps. I have your basic Shurflo 2.8GPM, 30PSI water pump and would like to either upgrade the pump to an Extreme 4.0GPM, 50PSI pump or keep what I have and add an accumulator. What I'm trying to achieve is more pressure, so my question is can an accumulator's pressure be adjusted?
Old-Biscuit
Verde Valley
Posted: 04/08/12 10:49am Link  |  Print  |  Notify Moderator
No..accumulator tanks only reduce pump cycling. They have to be set couple of psi less than pump discharge otherwise pump can not start or refill tank.
In order to increase line pressure & flow you have to have a higher discharge pressure & flow rated pump.
Check out reviews of the 'Extreme Series' pumps.......several have had problems.
What model # of Shurflo Pump do you have?
I have the 2088 model......2.8 gpm at 45#
You can increase the discharge pressure via an adjustment screw on end of pump head.....clockwise to increase BUT only in small increments.
Dusty R
Charlotte Michigan 48813
Posted: 04/08/12 12:04pm Link  |  Print  |  Notify Moderator
I've learned over the years that the higher the pressure the faster your waste tanks fill. I added the smallest size bladder type pressure tank available. They are made for homes that have their own water well. I'm very pleased with it.
Dusty
Latner
Indiana
Posted: 04/08/12 03:28pm Link  |  Print  |  Notify Moderator
Thanks. After taking a closer look at the pump, I have the same pump as you.
I played around with the screw and noticed if I turn to increase, the pump will run longer after turning the faucet off. How long is it suppose to run and what do you have yours set at?
Old-Biscuit
Verde Valley
Posted: 04/08/12 05:24pm Link  |  Print  |  Notify Moderator
My is set at #45 and turns off very shortly after closing a faucet.
 > Water pump
