bartiee
Amherstburg
With the brake control connected to the 5th wheel, should the brakes be locked on the trailer up when I manually slide the brake lever on full?
2008 Ram, 3500, quad cab, 4x4, 6.7,pulling a 2011 Cedar Creek 36RE
member of GOOD SAMS CLUB
aruba5er
Neenah Wisconsin
maybe, maybe not. depends on how adjusted the brakes are. are the shoes free of grease, dust? I know if I hit the manuel lever mine lock up. But I threw away those electric drum brakes 2 years ago. Hyd disk for me.
Old-Biscuit
Across the USA
I engage trailer brakes with manual lever to do a 'pull test' every time I hitch up.
Trailer brakes lock up.....truck grunts.....hitch is locked.
bartiee
Amherstburg
thanks for the info.. Mine can't be set properly. I'll readjust the unit.
Old-Biscuit
Across the USA
bartiee wrote: thanks for the info.. Mine can't be set properly. I'll readjust the unit.
Might not be the controller setting....
Have you checked/adjusted the trailer brakes?
DodgeVoltage
Nanjemoy, MD
I could never get my last fifth wheel's wheels to lock up. I had it back to the dealer many times and they couldn't figure it out. Changed the magnets, pads, wiring, and controller. They called the axle manufacturer many times and did everything they said to do. Still I had very weak brakes. Couldn't hardly feel them on the highest setting or manually squeezing the lever. I hated them.
2010 Dodge 3500 Mega Cab Cummins Diesel DRW
2009 GMC 2500HD D/A Crew Cab
2012 Dutchmen 3795 Voltage Epic Package
2012 Smart Passion for Two
2003 Suzuki Intruder 1500LC Cruiser
AD USAF 1996-2011 1700+ hrs E-3B/C AWACS
NYANG 2011-Present
K-State Wildcats!
skipnchar
Topeka or somewhere else
If they work at all it's more than likely a brake problem rather than a controller problem.
jwduke
Ice Cream Capital of the World (Le Mars), Ia.
I had this problem in our old Holiday Rambler. First, if you have one of those Teflon plates on your hitch, remove it, try your brakes again. If your brakes are better, try and find the ground for your 12V wiring (Camper). Clean connectors, and use some dielectric grease on the connections. Hope this works! Good luck!!
'04 Dodge 2500 QC 4x4 w/CTD
'03 Hitchhiker II 31RLBG
