RV.Net Open Roads Forum: dead battery ford edge while flat towing
 > dead battery ford edge while flat towing
scotttrz
illinois
Posted: 04/08/12 12:12pm Link  |  Print  |  Notify Moderator
while flat towing my ford edge battery will go completely dead have already installed switch to cut off dash etc still have same problem anyone have same problem
RognBon
Roseville, Calif.
Posted: 04/08/12 12:24pm Link  |  Print  |  Notify Moderator
What year is your Edge? We have a 2008 Edge and have never experienced a problem with a dead battery. If you have a newer model year with the keyless ignition I have heard of dead battery issues.
RognBon
1997 Monaco Dynasty 40'
Cummins 8.3 325 HP
2008 Ford Edge Toad
Retiredblade
Western, Pa
Posted: 04/08/12 12:25pm Link  |  Print  |  Notify Moderator
Don't have a edge, but have a 2011 Buick regal and it went dead, I fixed the problem, I just take neg battery terminal off, put it back on when I get there.
rvrepairnut
bc
Posted: 04/08/12 12:42pm Link  |  Print  |  Notify Moderator
skipole wrote:
Do you have a Breke Buddy installed? When we towed a Ford Escape with a BB it used to drain our toad battery flat every day we used it. Finally quit using it.
the only way the BB will kill the battery is if the Brake lites stick on for a hours on end
Unless the battery is recharged Properly it will go dead twice as easy the next time
2chiefsRus
USA Somewhere
Posted: 04/08/12 12:52pm Link  |  Print  |  Notify Moderator
Toad Charge
We installed this and haven't had any problems since. Makes for one less thing to remember to do. I'm sure there are other easier and cheaper ways but this came with everything that is needed and instructions.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2003 Odyssey
Fulltime since October 2007
Before you give someone a piece of your mind, make sure you can get by with what will be left.
skipole
Sandia Park, NM
Posted: 04/08/12 12:39pm Link  |  Print  |  Notify Moderator
tropical36
Southwest Florida_USA
Posted: 04/08/12 12:55pm Link  |  Print  |  Notify Moderator
Are you using toad power for braking or anything else. If not required, then get yourself a battery disconnect and install it on the the neg. battery terminal.
I plan on using a READY BRAKE that doesn't require any power and since I don't have a steering wheel lock on our Wrangler either, then I should be good to go.
"We are often so caught up in our destination that we forget to appreciate the journey."
1998 36ft. National Tropi-Cal Model 6350 on a 1997 Chevy P32
Chassis_7.4 Vortec Engine_4L80E Tranny_slide_tag axle.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
bruexxx
SUMMERLAND BC
Posted: 04/08/12 01:34pm Link  |  Print  |  Notify Moderator
We also flat tow a 2008 Ford Edge,haven't had a problem so far.
John&Joey
Some Location
Posted: 04/08/12 03:11pm Link  |  Print  |  Notify Moderator
I use a BB and do for multiple days in a row even. Never had a problem.
To the OP, maybe you have a simple answer like you have a dead cell in the battery and nothing to do with towing. Take it to someplace that will test the battery to make sure it's good and can hold a charge.
There are ton's of us out there that flat tow (with braking units) that never have problems.
bass n bob
new york state
we towed an Edge for 2 years without the problem. We installed a charging line from the MH and that seemed to work well.
