RV.Net Open Roads Forum: Towing: Ordered a Titan Hitch for my '02 Silverado
Search only in Towing
Open Roads Forum  >  Towing
 > Ordered a Titan Hitch for my '02 Silverado
Mkos1980
Macedonia Ohio
Posted: 04/10/12 08:20pm Link  |  Print  |  Notify Moderator
Very easy. Hardest part was getting the bumper brackets moved away so you can ron the vertical brackets.
I also updated mine as my trailer is alot smaller then the stock rating for the hitch but I tow my fathers boat as well which is also north of 13K lbs
2003 Springdale 269RLLS TT
1990 Chaparral 2150SX 350 MAG
2006 Chevrolet 2500HD 6.0
1989 Pontiac Formula 350 "LSX"
taken
Western MA
Posted: 04/11/12 06:13pm Link  |  Print  |  Notify Moderator
I put the same one on my 09 F250 and was very disappointed. Using the adapter sleeve is a nuisance when using a 2" ball mount as it always slides in with the hitch leaving the pin holes not aligned. Also, the adapter is way to big for all 2" hitches out there and when the hitch is in there it's very sloppy. I've read on a few forums where people have had real wear issues when using the adapter sleeve due to it's misfit. Be careful... Also, the ratings drop when the sleeve is used so don't be impressed by it's high numbers unless you buy a 2.5" ballmount. Yes, installation was easy, but even knowing that, I let it go when I traded for my 12. I'd go another route if I was to upgrade again.....
TV - 2012 F350 SC SB 4X4 6.7
TH - 2013 Heartland Road Warrior 30C
overdrive75
Whitmore Lake, MI
Posted: 04/14/12 12:58pm Link  |  Print  |  Notify Moderator
Well I installed this today and of course forgot to photo the install process. So I snapped a shot before letting the hoist down. 17,000 lbs of trailer capable now.
Oh yeah the opening is 1.25 inches higher so time to reset all the trailer inserts.
2002 Chevy 2500HD 4x4 6.0L 4L85E 4.10 Full Floater 9200GVW 16K GCVW
2009 Rockwood Roo 23SS for camping
1989 Searay 230CC for the weekends when not camping.
