rgolding
Southern Illinois
Thought I'd clean and inspect the roof of the trailer this afternoon. Had purchased some Dicor Roof Cleaner to do the job and I really thought it would do a better job than it is doing. So some guys have said try Murphy's Oil Soap or Spic and Span. I know what Murphy's Oil Soap is like, but there is a liquid or powdered Spic and Span, which one are you talking about?
The Dicor did not take all the leave stains and mildew out. Its cleaner, but not what I would call clean. The roof seams to be in good shape, but just doing my bi-annual inspection.
tight-loops
here
Either "Reliable RV Cleaner" or "Korkay" will clean it to white. Best black streak removers as well
gpaus220
madison south dakota
tight-loops what korkay product do you use?
newf6969
Pensacola FL
We use Borax and white vinegar cleans it right up!!!
belairbrian
Alabama
I use the liquid spic and span.
TV 2003 Chevy 3500 Crew Cab Dually w Duramax/Allison
2005 Keystone Cougar 314 EFS
Reese 16K Slider Hitch, Prodigy BC, Delorme GPS
USAF Retired
eddie3260
Florence, al
Simple Green works well. I cleaned my awning and roof with it a couple of weeks ago. Both look great.
Charltons
Battle Ground, WA
eddie3260 wrote: Simple Green works well. I cleaned my awning and roof with it a couple of weeks ago. Both look great.
X2 on the simple green. Great stuff.
2012 Dodge Ram 2500 Crew Cab 4X4 TCD
2012 Keystone Sprinter 311BHS
Highway 4x4
La Verne, Ca
I used tide with bleach powder. Wet down roof, threw powdered tide, scrubbed with a brush. Then coated roof with EDPM liquid roof. Roof is done for many, many years.
LarryJM
NoVa
rgolding wrote: Thought I'd clean and inspect the roof of the trailer this afternoon. Had purchased some Dicor Roof Cleaner to do the job and I really thought it would do a better job than it is doing. So some guys have said try Murphy's Oil Soap or Spic and Span. I know what Murphy's Oil Soap is like, but there is a liquid or powdered Spic and Span, which one are you talking about?
Other than a little better reflectivity from the sun, why are you worried about getting it looking like new. You can let it turn completely black and it won't effect the life span of the EPDM roof. I might clean mine a little every 3 or 4 years and that is mainly to get some of the tree debris from around the A/C off. IMO people obsess WAY TO MUCH about trying to keep these EPDM roofs clean. The material is used commercially and they NEVER TOUCH it until it needs to be replaced 20 or more years later.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
tdeal823
N.W. Ohio
Larry,
I see your point and thought the same with my 1st TT that I just sold last year. It was a 2000 Rockwood. We never touched the roof and never had a problem. recaulked it every few years and that was it. My only thought is that the "dirty and unprotected" roof is the major cause of my black streaks. I could be wrong. I really don't know what actually causes the black streaks other than dirt.
However after spending lots of my hard earned money on a new 5er last year. I find myself reasearching new methods to keep my camper clean. Going from a 30' TT to a 35' 5th is quite a bit more surface area to keep clean. So if I can do a few spring weekends of wash, wax, and protect to ease my normal after trip cleaning, I'm very interested.
What are your methods on cleaning? If you are only cleaning the sides of your camper. Do you have black streak problems? Or maybe you are using a better more effective wax?
Thank you for info
Tony
2008 Silverado 2500HD DMax LTZ cc sb 4x4 EFILive tuned, Blocked, Deleted, Rerouted and removed B&W Turnover ball and 5th Companion
02 F250 4x4 Auto Ex LWB SRW 7.3L B&W, RideRite, 5"exhaust. TW6 chip. 195k
2011 Sabre 32BHOK-6
