RV.Net Open Roads Forum: Truck Campers: Arctic Fox Questions
 > Arctic Fox Questions
martyn8677
Celina, Texas
Posted: 04/08/12 08:28pm Link  |  Print  |  Notify Moderator
I have an 09 990. Can anyone tell me where to find the battery kill switch?
Also, when one propane tank runs out does it switch automatically to the other or does it need to be done manually?
Thanks
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/08/12 08:45pm Link  |  Print  |  Notify Moderator
Hmmm. I don't think most campers come with a battery disconnect switch. Most I have seen, the owner has put it in himself.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
n7bsn
Yes
Posted: 04/08/12 08:59pm Link  |  Print  |  Notify Moderator
Northwood typically puts them near the battery, that being said only one of my two had one.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
synergy_58
JBER, Ak (Anchorage)
Posted: 04/08/12 09:15pm Link  |  Print  |  Notify Moderator
Look in the sink cabinet. Mine is in the sink area cabinet just behind the ink. Big red knob, ays kill switch.
John & Angela
Full Timers in Canada, USA and Mexico
Posted: 04/08/12 09:20pm Link  |  Print  |  Notify Moderator
Under the sink, right hand side. The transfer switch is also there (square box in the back. Also the brain for the electric jacks.
Yes, your propane will automatically switch over.
2003 Revolution 40C Class A. 2002 Vanguard 22 foot Class C. Diesel smart car Toad or pulling a 2009 Timeout Tent Trailer.
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
jr3316
Mount Shasta, CA
Posted: 04/08/12 10:52pm Link  |  Print  |  Notify Moderator
Mine is located under the sink.
Here is a photo link:
http://i1121.photobucket.com/albums/l508/jr3316/114.jpg
2008 Dodge Ram 3500 6.7L, Automatic, Quad-Cab 4x4 DRW Diesel
Torklift Tiedowns, Rancho 9000xl wireless, Firestone Airbags, Fastguns, Helwig Bigwig Sway Bar, Torklift Stable Loads, Morningstar 300W Inverter
2006 Arctic Fox 1140 Dry Bath
insp1505
Idaho
Posted: 04/08/12 11:35pm Link  |  Print  |  Notify Moderator
Your 09 AF should have a factory installed battery kill switch. Like others said it should be under the sink. On my 2010 it's attached to the front wall under the sink next to the electric jack controller.
The propane switches automatically. Point the lever at the first tank you want to use, when it changes over there is an indicator on the switch valve that turns red to let you know it is now drawing off the tank that the lever is NOT pointing at. That way you know the first tank is empty.
Mello Mike
Mesa, AZ
Posted: 04/09/12 04:44am Link  |  Print  |  Notify Moderator
Yep, it's in the same location in the Wolf Creek campers too.
2011 Wolf Creek 850N/Polar Cub/240w Solar/2-6v Lifeline AGMs/Morningstar Sunsaver w/RM-1 & SureSine-300 Inverter
2011 Ford F-250/6.2L/3.73/Bilsteins/Air Bags/Torklift TD w/Fastguns
2004 Jeep Wrangler/4.0L/5-spd
US Navy Ret.
My Truck Camper Adventure Blog
martyn8677
Celina, Texas
Posted: 04/09/12 06:27am Link  |  Print  |  Notify Moderator
thanks everyone, that's the one place I didn't look.
