FJ60Kai
Oregon
Since my new(er) truck is a 2008 Chevy 4x4 dually with air bags, I really don't need the weight distributing hitch anymore (and honestly don't feel a difference so I havn't be using the weight dist. bars). My question is, is it a bad idea to use the hitch without the weight bars also? Aside from the hitch weight itself, and the slight angle it has, I don't see much difference. So is there any concern running it without the bars?
bob213
Fresno, CA
Shouldn't be a problem but a nice aluminum drop hitch would look alot nicer on that 2008 dually. Myself, if I had the WD hitch, I would use it...with the bars.
robsouth
Near Atlanta, GA
Totally depends on the tongue weight. Does it excide the rating for the hitch or not? Bars increase the available tongue weight. Do the numbers.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
lincster
Mesa Az
Your stock hitch probably says 500lbs without WD bars.
You won't get a toy hauler with that light of a tongue weight.
2012 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
robsouth
Near Atlanta, GA
lincster wrote: Your stock hitch probably says 500lbs without WD bars.
Just sayin'
HTElectrical
Las Vegas
You did read th op posts where he states it is a new Dually didn't you??????????????
2007 Duramax, Cognito 7"-9" Lift, 35" Hankooks
2009 284SA Vortex
chuggs
Doesn't the ball pivot +12 degrees/-3 degrees?? I would just go get a regular draw bar and ball instead of useing the WD hitch without the bars. I really don't think that un-arrested banging back and forth on the hitch ball would be a good thing.
shagan77
Ozarks
I could be mistaken but my stock hitch on my 09 Chevy Dually was rated at 1000 lbs. I picked up this handy little gadget to make my towing life much easier as every trailer I own or tow has a different hitch size. I've also towed using the WD hitch without the bars, looks linda tacky but works fine.
2013 Sierra Denali 3500 Duramax\Dually
2011 Cyclone 3950 HD
2009 Harley Davidson Ultra Classic
2011 Can-Am Spyder RT-S Limited (DW's)
Usually a keg of beer....
lincster
Mesa Az
HTElectrical wrote: lincster wrote: Your stock hitch probably says 500lbs without WD bars.
What difference does that make? The hitch is rated to a certain weight without WD bars. I don't care what it is hooked to.
SoCalDesertRider
SanDiego, CA, USA
There is no problem using a weight distributing hitch shank and head without the spring bars to tow a trailer with. I have done it many, many, many times, for years.
This is provided that your hitch receiver is rated to carry the trailer's tongue weight without using the spring bars, of course. My hitch is a class 5, rated to 1200 lbs without weight distribution.
If you're going to be using the hitch without the bars on a permanent basis, I would adjust the ball tilt angle to level. Also, adjust the ball height to ensure the trailer is towing level without the bars. Other than that, carry on.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
