RV.Net Open Roads Forum: Beginning RVing: Old Geni with old fuel?
 > Old Geni with old fuel?
Blanco1
Los Angeles
Posted: 04/08/12 09:51pm Link  |  Print  |  Notify Moderator
So I got my Geni running & its sorta rough?
& a friend tells me it might be old varnish in the carb etc?
So he suggest I run a fuel treatment through the fuel tank?
What do you guys think?
What the best treatment to deal with an old fuel issue?
1997 Dodge 4x4, 5 spd manual trans & HotRod 5.9 cummins.
With '85 Lance.
robsouth
Near Atlanta, GA
Posted: 04/08/12 09:57pm Link  |  Print  |  Notify Moderator
Start Your Engines. Works really well.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
BobJoh
Whitestown, IN 46075
Posted: 04/08/12 10:15pm Link  |  Print  |  Notify Moderator
SEAFOAM for fuel treatment.. put it in the fuel tank..
BobJoh
Blanco1
Los Angeles
Posted: 04/09/12 02:30am Link  |  Print  |  Notify Moderator
Never thought about that for the Geni, might be a great idea! Thanks.
veronicaB
Los Angeles, CA
Posted: 04/09/12 03:10am Link  |  Print  |  Notify Moderator
Prepare yourself and start the engine smoothly.
tvman44
Southwest Louisiana
Posted: 04/09/12 05:00am Link  |  Print  |  Notify Moderator
Put Seafoam in the Tank and run for awhile then let sit for a day with the fuel Seafoam mixture in the carb then start again and run for awhile. Seafoam is wonderful stuff, has saved many a carburetor.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
gbopp
The Keystone State
Posted: 04/09/12 06:46am Link  |  Print  |  Notify Moderator
x2
mowermech
Billings, MT
Posted: 04/09/12 07:00am Link  |  Print  |  Notify Moderator
Yes, "chemical overhauls" sometimes work. For a while.
For best results, remove, disassemble, thoroughly clean, and reassemble the carburetor with a rebuild kit. Then make the proper adjustments to get the governor set right for the correct voltage and cyclic rate.
If it is done right the FIRST time, it probably won't have to be done over.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
n7bsn
Yes
Posted: 04/09/12 09:25am Link  |  Print  |  Notify Moderator
Every time I put new gas in the 5 gallon, I put in a modern fuel treatment, period.
Current gas can go bad more quickly then we know, modern "gas" is 89 percent gas, 10 percent "water attractant" (ie ethanol) and 1 percent******that cuts the shelf life to weeks.
It's not like 20 years ago when gas could last years.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
2oldman
Winchester WA
Posted: 04/09/12 09:34am Link  |  Print  |  Notify Moderator
New fuel.
