RV.Net Open Roads Forum: Strange looking wiring socket ? or connector
 > Strange looking wiring socket ? or connector
MrWizard
Traveling
Posted: 04/10/12 10:04pm Link  |  Print  |  Notify Moderator
shut down all power and install the needed normal DUPLEX outlets
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
mercedesme28
Queen Creek
Posted: 04/10/12 10:12pm Link  |  Print  |  Notify Moderator
at this time, my rig is not connect to power, only the battery's so if I flip off the breakers,(just to be safe) your saying I can add a standard household Outlet,like I would find at a home improvement store ? my bed doesn't plug into anything like this, just a standard plug. so I could mount a box on the wall and install a plug ? would you suggest I stick to a 2 outlet set up, or can I get 4 outlets out of this wire ? after all most people add 2-3 power strips and load them up, (not me) ha ha but with extra plugs I could avoid the power strips. would a GFI plug set up be wise ? or would it matter with the breaker's ?
Thanks again for any advise/help and suggestions to each of you.
rk911
Wheaton IL
Posted: 04/10/12 10:26pm Link  |  Print  |  Notify Moderator
as mr. wizard wrote, a std duplex (2 outlet box) should be fine. if you use surface mounts be sure there is enough room for your mattress. planning is everything.
73,
rich, n9dko
www.bananaboatbytes.com
I know a guy who's addicted to brake fulid. He says he can stop anytime.
2000 Itasca Suncruiser 35U
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
Jim@HiTek
Gresham, OR, USA
Posted: 04/12/12 04:33pm Link  |  Print  |  Notify Moderator
You can put as many outlets as you like. As long as you don't exceed the rating of the circuit breakers to loads that are too big, you're safe. Within reason.
* This post was edited 04/12/12 05:02pm by Jim@HiTek *
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
mercedesme28
Queen Creek
Posted: 04/12/12 06:42pm Link  |  Print  |  Notify Moderator
OK, it's getting strange, when trying to find out which breaker controlled this line, I went and turned on each breaker 1 at a time,(there is only 5 breakers, 1 goes just to the Micro) it turns out that I must have all 4 on in order to get power to the line. isn't that wrong ?
Jim@HiTek
Gresham, OR, USA
Posted: 04/12/12 07:02pm Link  |  Print  |  Notify Moderator
Weird. Yes, that sounds wrong. There should be ONE breaker that powers that line. Not four.
Could it be that it happened to be the last one you turned on?
mercedesme28
Queen Creek
Posted: 04/13/12 01:03pm Link  |  Print  |  Notify Moderator
I'll pull it and look it over later today and post what I see, or don't see.
Thanks for every ones help and input. just a Note, I showed camping world that plug and they had no idea..ha ha ha
mercedesme28
Queen Creek
Posted: 04/12/12 07:37pm Link  |  Print  |  Notify Moderator
here is another part of the picture. one 1 side of the bed I have a cable coming up from the floor,(it has 3 wires in it) on the other side of the bed I found 2 cables coming up and their were connected. after taking these apart, I found that one is a ponytail used to power the other side of the bed. so I have only one hot ... wire in total. so once I tested all the wires and found this out, I then turned off all of the breakers and tested again,(no power) which is right, then I would turn on 1 breaker test...not a single breaker gave power, so I turned them all on, got power, this time I would turn off a breaker to see which gave power, it did not matter which one I turned off, if I turned of 1 of the 4 breakers I lost all power, did not mater which breaker crazy huh...
the only thing I can think of is this last summer we had a Park Blow my converter and melted my outside power plug, I put a better one in, just as if said,(only 2 wires and a ground) and everything works great, until I wanted to use this old wire. ha ha ha could my breakers be bad ? could they be fused,(no pun intented) somewhere behind the panel cover ?
Jim@HiTek
Gresham, OR, USA
Posted: 04/12/12 09:21pm Link  |  Print  |  Notify Moderator
Well, I would certainly pull the panel and look. Strange things can happen. I've been in the electronics business for 50 years and this symptom has me puzzled. I'd be interest to know what you find out.
mercedesme28
Queen Creek
Posted: 04/13/12 10:34pm Link  |  Print  |  Notify Moderator
OK, I took off the Panel cover, took a picture and went to a Builders Supply where I explained it all, and after seeing the same look on his face as I'm sure you all had,(including myself) he had me test a few things and it turns out that my Main was not marked correctly and once that fell into place it all came together, I now know which breaker goes where,(besides the photo's I'm drawing it out) as suggested for future questions.as well as Marking which one goes where. the outlets will go in on Sat. and all is good now in the land of OZ...
Thank Each of you for your Help, insight and idea's,
it's this type of help that make this Website work.
So Once again, THANK ALL OF YOU FOR YOUR HELP.....
