RHR
Tecumseh, Kansas
In viewing postings about 2 to 3% are wider than my screen causing the bar to show below the posting to move it from side to side to
finish the reading or view a picture. Is there any way I can fix this so that won't happen on this site?
Hitchhiker 2 LS RKTG 32.5
Chevy 3500 Duramax,Allison 2004 SRW
1492
Washington, DC
Not likely. They tend to be caused by members posting photos whose width far exceeds the Forum's recommended 640pix.
wittmeba
Virginia
Some forum software also has the ability to compress the "displayed" url but maintains the integrity for the complete url behind-the-scenes.
I was born in Great Falls, Mt. My parents moved when I was 5. I found them when I was 10 - they were in California.
Firefox® 21.0
Log home images - Updated 05/19/2013
pulsar
Lewisville, NC
Although "too-wide" pictures are the main culprits causing side scrolling, long URLs or a long line of characters, with no spaces can cause side scrolling. Some members will put in a long line of dashes (--------------). If it is longer than the screen is wide, the display engine has no way to wrap the line.
Most long URLs are not a problem, because the display engine can find a place to break, for example a dot '.'
Tom
SolidAxleDurango
OK, USA
I wish this forum would get up to speed with the other forum software available.
Most of them detect the resolution/size of the pic posted within a thread and automatically size the image to fit within the reader's browser. If the reader wishes to see the full size image, all they have to do is click and it will show as full resolution.
Moderators constantly editing user posts to 640x480 is both annoying (I want to see the full size) and archaic (really? we have to post at that microscopic size - the 90s called and they want their monitor back)... It's likely a time consuming/tedious task.
TV = 07 Dodge Ram 3500 Dually 6.7 / QC-LB / CTD / G56 / 3.73 / 4wd / EBrake
5er = 12 Keystone Avalanche 330RE
Toys = 08 Kawasaki Brutie Force 650i 4x4 ( x2 )
BobsYourUncle
Surrey, BC Canada
When you encounter one of those posts, try holding the CTRL key down and using the scroll wheel on your mouse. You can make the whole screen smaller, thus including all of the width of the post.
Scroll towards you to make everything smaller on the screen.
Duramax / Allison
Fire Red
95 Sportsmen 25.5' TT
81 Citation 25' "Tail dragger" "Under construction"
"Workin' man's rig"
Bob's Trucks
Check Out My Rebuild Project
Project Feedback
NorthernLimits
Michigan
Set your resolution higher. 640x480 is so 20 years ago.
Use control - (command - on a mac) to zoom out.
pulsar
Lewisville, NC
wittmeba wrote: Some forum software also has the ability to compress the "displayed" url but maintains the integrity for the complete url behind-the-scenes.
The forum software will "compress" long URLs, if the poster uses the message window's Link tool,
Tom
