RV.Net Open Roads Forum: Tow Vehicles: GM built in brake controller question
Search only in Tow Vehicles
 > GM built in brake controller question
AZ T&T
Mesa, AZ
Posted: 04/09/12 06:26pm Link  |  Print  |  Notify Moderator
I had my prodigy set at 9.0 and on my GM I'm at 5.5. It seems like the GM controller was much stronger.
AZ T&T
2012 Jayco Eagle Super Lite 29.5RKS
2011 Chevy 2500 HD 4x4 Duramax
B&W Companion Hitch - Firestone Ride-Rite Air Bags
Honda EU2000i Generator
therink
Rochester
Posted: 04/09/12 06:33pm Link  |  Print  |  Notify Moderator
4x4ord wrote:
It is true that the IBC's work so much smoother that you don't feel the trailer brakes jerking the truck, but when you manually apply the trailer brakes, your trailer wheels should lock up if the gain is set up to max. Not that you would want to operate them turned that high.
At max gain 10.0 with lever fully engaged, the wheels don't lock at slow speed but do jerk the truck and stop fast. With the gain set at max at highway speeds, the trlr wheels don't lock but do engage, just not as hard as the Prodigy controller. I have never been able to lock up the wheels on dry pavement with this 12k lb. fiver, even with the Prodigy. . Should they lock up?
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
