RV.Net Open Roads Forum: videos of honda 2k unit attempting to run an air conditioner
 > videos of honda 2k unit attempting to run an air conditioner
Page of 6
Cedarhill
Deep South
Posted: 04/09/12 09:34am Link  |  Print  |  Notify Moderator
I agree with Bill. Abusing the generator and compressor motor in this way is probably not a good idea, regardless of whether it actually works long enough to demonstrate.
Wayne Dohnal
Bend, OR.
Posted: 04/09/12 09:42am Link  |  Print  |  Notify Moderator
And why doesn't anybody ever seem to think that running a 1,000 microwave, which draws more than many 13,500 btuh air conditioners, abuses the microwave or generator?
2009 Fleetwood Icon 24A
Honda Fit dinghy with US Gear brake system
LinkPro battery monitor - EU2000i generator
pianotuna
Regina, SK, Canada
Hi,
My best guess is that running an air conditioner on a 2k genny is not going to do much good to the motor for the compressor. 59 volts is...abuse.
I love mexbungalow's microwave test for alternative and shore power sources. At least a microwave is cheap to replace compared to an air conditioner.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
pianotuna
Regina, SK, Canada
Posted: 04/09/12 09:45am Link  |  Print  |  Notify Moderator
Hi Wayne,
My micro draws 1591 watts. No way I would run it on a Honda 2k unit. I'm waiting for that magnum 2800 watt inverter. It will be this years major upgrade!
jauguston
Bellingham, WA
Posted: 04/09/12 09:46am Link  |  Print  |  Notify Moderator
Is it abuse when the video showed the low voltage was no more than one second?
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
pianotuna
Regina, SK, Canada
Posted: 04/09/12 10:03am Link  |  Print  |  Notify Moderator
Hi Jim,
Yes it is still abuse, because it means the hard start capacitor was not able to hold enough energy to support the voltage. Maybe with an even bigger capacitor? (Or two in parallel?)
ScottG
Bothell Wa.
Posted: 04/09/12 02:47pm Link  |  Print  |  Notify Moderator
That was with the poor little Honda on Eco though. I'd like to see how it does with it off since the Eu2000i has a very good surge capacity.
Scott, Grace and Wesly
H0NDA eu2000i
12thgenusa
Lakewood, Colorado
Posted: 04/09/12 10:07am Link  |  Print  |  Notify Moderator
What happens a while later when the compressor cycles with the genny already in eco mode?
Dave & Gean
2007 Tundra DC 4X4 5.7
2009 Cougar 245RKS
370 watts ET solar
Rogue 3024 MPPT controller
440 Ah battery bank
ProWatt 2000 inverter
mena661
Posted: 04/09/12 11:24am Link  |  Print  |  Notify Moderator
pianotuna wrote:
Hi Wayne,
You're going to get one??? Sweet!!!!
Trojan L16 6V's 740 Amp-hours
mlts22
Austin, Texas
Posted: 04/09/12 12:25pm Link  |  Print  |  Notify Moderator
59 volts isn't good for either the compressor (likely dealing with a heavy load from being on), nor the generator. Three words: Locked rotor amps. For a 13500 BTU A/C, the inrush current can get to 40-60 amps.
IIRC, eventually the generator will go into overload mode, but it isn't good for the inverter part to be pushed to the edge of tripping that often.
Personally, I'd just get another eu2000i and a parallel kit, and at least know that I'm not going to sizzle my A/C unit. Just the cost of replacing the unit will be as much, if not more, than the cost of the MSRP on the second generator.
Page of 6
