RV.Net Open Roads Forum: Fifth-Wheels: Tire Pressure
 > Tire Pressure
Sandy & Shirley
North East, MD
Posted: 04/09/12 08:08am Link  |  Print  |  Notify Moderator
What Tire Pressure do you usually run in your fifth wheel tires?
'02 F350 7.3PSD CC LB DRW, Reese 20K Hitch, Brake Smart, AirLift, C-betr mirrors,
'04 Everest 343L, TrailAir, RotoChoks, Wayne's stabilizer
Toys: Fold-Away Pet Carrier, Thermos Grill 2 GO
For more info, visit Our RV web site.
donn0128
Pronounced Ore-gun
Posted: 04/09/12 08:15am Link  |  Print  |  Notify Moderator
Max as listed on the sidewalks. Anything less, especially with an ST tire and your load rating is reduced.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
AZ T&T
Mesa, AZ
Posted: 04/09/12 08:24am Link  |  Print  |  Notify Moderator
Max - its better for the side walls.
AZ T&T
2012 Jayco Eagle Super Lite 29.5RKS
2011 Chevy 2500 HD 4x4 Duramax
B&W Companion Hitch - Firestone Ride-Rite Air Bags
Honda EU2000i Generator
Jim Cindy
Northcentral, PA
Posted: 04/09/12 08:29am Link  |  Print  |  Notify Moderator
Gonna get a lot of replies. We always have and always will use the max pressure shown on tire sidewall. Had flats (nails, screws, wire)and the infamous Duro tires but no blowouts on a popup and 4 different 5th wheels over 40+ years.
PBH Portable Beach House
2008 GMC 2500HD Duramax Allison
2009 Cameo 34CK3
MorRyde IS, Disc Brakes, G614's
PullRite Super Glide Hitch
Propane fueled Yamaha EF 2400is
ExRocketScientist
Laurel, MD
Posted: 04/09/12 08:45am Link  |  Print  |  Notify Moderator
Max on the sidewall. Trailers are usually loaded to the maximum capacity of the tires or more.
ERS
bpounds
Whittier CA
Posted: 04/09/12 09:04am Link  |  Print  |  Notify Moderator
Max is good, although I sometimes like to run about 5psi below max. But that depends on whether I am near the max load rating. There is no reason that I can think of to run below the max. The tires run coolest when inflated to the max.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
wandering1
Posted: 04/09/12 09:35am Link  |  Print  |  Notify Moderator
???? Depends on the tire and the tire size. Run the PSI indicated on the sidewall for all tires.
HR
Dennis M M
Geneva, IL; Tucson, AZ
Posted: 04/09/12 10:48am Link  |  Print  |  Notify Moderator
Weigh the fiver then consult a weight chart for your tire brand and size to get the CORRECT pressure. Several problems can occur when running higher than needed pressures, not the least being increased susceptibility to road hazard damage, another being a rougher ride than necessary for your fiver.
I have towed over 60k miles with all eight tires on the 18k lb. fiver (yes, twin axle dually) set at 65 PSI cold. One leaker due to picking up a nail, never a problem on the road. The Pressure Pro makes it real easy to monitor the pressures.
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'11 smart fortwo on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
DW-gray
Tulsa, OK -> Goshen, IN
Posted: 04/09/12 10:55am Link  |  Print  |  Notify Moderator
Completely agree with the above. Only if you're able to weigh each trailer wheel or as a minimum, each axle, would you consider inflating less than the maximum allowed tire inflation pressure or what is written on the trailer's certification label. You don't want to experience the results of under inflation pressure.
Dave & Amy
Fifth Wheel St. 13 Point Safety Report including -7 Point Safety Margin vs. Overload
Before You Buy That RV, Truck or Other Tow Vehicle
08 Dodge Ram 3500 4X4, Dually, 6.7L Diesel, 09 Heartland Cyclone 4012 with smart car in the garage.
j2catfish
Newport, NC, U.S.of.A.
Posted: 04/09/12 10:59am Link  |  Print  |  Notify Moderator
110 PSI
K3500; Teton Homes 5er;
Native Texan - Transplanted Tar Heel
Retired USMC Mustang (LDO)
Semper Fi !
 > Tire Pressure
