RV.Net Open Roads Forum: Beginning RVing: How much power do I need?
 > How much power do I need?
cm
Dillon, CO USA
Posted: 04/09/12 03:25pm Link  |  Print  |  Notify Moderator
He said that he will mostly use it the race tracks.
Several people are talking about generator hours. Have you ever been to a race track pit? They do not usually have generator hour restrictions. Often generators are run as much as 24 hours a day for the length of the race.
He is not talking about some campground or state park.
jgos929
TX
Posted: 04/09/12 05:45pm Link  |  Print  |  Notify Moderator
Exactly right. We run them all day and all night and most of the folks out there just accept and deal with the noise.
TV: 2012 Dodge Ram Crew Cab HEMI
TT: 2006 KZ Jag 29JB
DSDP Don
Moorpark, Ca
Posted: 04/09/12 06:33pm Link  |  Print  |  Notify Moderator
jgos929....If its a newer Honda, you can buy the second Honda designed to paired up. The auxillary fuel tank kit is also a nice option for extended running.
Very few people know that there is a security handle made for the 2000 Honda generators. The handle on the 2000 is only plastic, but many run their cable locks through the handle. A hacksaw will quickly saw through the handle. Honda makes a metal sleeve sleeve that fits over the handle and once secured, can't be removed or easily cut. Here is the lock.
Don & Mary
2014 Newmar Dutch Star 4018 - All Electric
Cummins 450ISL
2016 GMC Canyon 4WD Crew Cab
PhilR.
Central Texas
Posted: 04/09/12 07:27pm Link  |  Print  |  Notify Moderator
If I were to be running a generator in your specified setting, I would just go to the local Tractor Supply Store and pick up a Champion 3500 genset for $299. They will run one A/C unit, along with the rest of the stuff in the trailer quite well. These gensets are louder than the red or blue ones, but still produce much less noise than the typical contractor-style gensets. IOW, it will fit in just fine in your particular setting.
The Champion provides more performance for the dollar spent than any other genset I've seen or used so far. It also has an RV plug built in, so no adapter needed. The only thing I don't like about them is that they weigh about 100 lbs.
jgos929
TX
Posted: 04/09/12 08:10pm Link  |  Print  |  Notify Moderator
Thanks for the link
jgos929
TX
Posted: 04/09/12 08:11pm Link  |  Print  |  Notify Moderator
I've been looking at the champions and have heard good things about them
