RV.Net Open Roads Forum: Can Anyone Tell Me How to Replace a SureFlow Water Pump?
 > Can Anyone Tell Me How to Replace a SureFlow Water Pump?
Handbasket
Asheville, NC
Posted: 04/10/12 06:15am Link  |  Print  |  Notify Moderator
If it's one or more of the push-on connectors, usually a gentle squeeze with pliers, as mentioned above, will cure it. Best to do it with the power to the pump off. Place the pliers so that you're squeezing wide-side to wide-side on the white plastic of the connector. The idea is to deform the metal inside the plastic just a bit to tighten the push-on connector.
Jim, "Mo' coffee!"
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory') www.tigervehicles.com
kneal44
EAST CENTRAL TEXAS
Posted: 04/10/12 07:19am Link  |  Print  |  Notify Moderator
it is possible you have loose or corroded connections... pull out one line feed to pump at a time and see is you can squeexe the female connector so it is tighter for the spade slide in connection. dont squeeze it too much . trial and error just a little bit. see if that solves your problem .
sounds like you have loose connections.
when u play in the sand .... you can get stuck
9-24-08 corpus christi padre island texas. wrecker had to haul me out!
'92 dp 5.9 cummins 190 hp....8mpg yuck!
CoachTraveler
Posted: 04/10/12 03:22pm Link  |  Print  |  Notify Moderator
This site is Awesome!
Thanks to all of you for your Prompt feedback!
I will definitely try the "Squeeze" on the Female Connectors
and Report back...
