Mafusa
Puget Sound
Hi there, Brand new to this. Just bought a used 30' 5th wheel (Arctic Fox 295T if that makes any difference). Tow vehicle is 2008 GMC 2500HD with Duramax, 2wd. Here is the question. When the folks built this house they built a driveway down the hill to a big pad and a 30x40 shop, RV storage building. I think the guy had plans for a Class C that he would store down there.The problem is the driveway is very steep. Just measured the slope with my iPad and it is a little over 12 degrees, which equates to 20% slope. Not a long driveway but a steep one. The question is can I tow this unit (13k loaded, less without fluids) up this hill or should I plan on finding someplace sane to store it?
Thanks, Steve
If you always find the answer, try asking harder questions....
mpfireman
Cook County Il
I would think that you would be OK, as you will be going less than 1 MPH, and in low gear when pulling that grade. You might have an issue with the trailers tail dragging on the ground, but again, it depends upon how everything is laid out. Question, is the driveway Concrete, Black top, Stone, Grass and stone? Loose type of materials will result in wheel slippage.
1998.5 Dodge Ram Quad Cab Cummins
1998 Sunnybrook 27RKFS Fiver
Mafusa
Puget Sound
concrete. The Arctic Fox sits high and the entry to the slope seems gradual enuf that I would think it wouldn't drag. Thanks for the quick reply.
archie780
Edmonton
edited 04/26/12 08:42pm by archie780 *
Mafusa
Puget Sound
Thanks. Good reminders
skipnchar
Topeka or somewhere else
The GRADE should be no problem but the transition COULD be a real pain if it's sudden. It would be pretty easy to tail drag even a full height trailer transitioning from flat to that steep quickly. could also be some clearance problems with the truck and trailer so keep that in mind the first time up the hill (and the first time down)
Artemus Gordon
Redding California
We built an RV pad that we don't use. It is steep and the "one time" we moved our trailer up the driveway it convinced us of two things. 1. The drama of using driveway caused, was not worth it! $80.00 per month for a secure flat "easy access" storage facility was worth it!
laknox
Arizona
Mafusa wrote: concrete. The Arctic Fox sits high and the entry to the slope seems gradual enuf that I would think it wouldn't drag. Thanks for the quick reply.
With the driveway being concrete, if you do experience any slipping, you can always have the surface grooved to provide a bit of grip. Just might have to hose it off if it fills with dirt, in between.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 60 Year Member
Ed9824v
Agua Dulce, Calif. 70 mi N.E. of Los Angeles
are you going to back in or go forward, my boys father in law had a brand new dodge and backed his trailer up his driveway very steep to put in his shop and the trans burned up 1st time out. He now has a f450 4x4 and has not had any problems.
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
korbe
California
We have a 300ft driveway at 25%. I put the truck in 4 low and take it slow. I am more concerned with kicking gravel than not having enough power.
