RV.Net Open Roads Forum: Class C Motorhomes: Marker light problems
 > Marker light problems
cncdude
Racine, WI.
Posted: 04/09/12 01:42pm Link  |  Print  |  Notify Moderator
I have a 2007 Fourwinds 33K (C5500). The orange marker lights on top in front and the side have no power. The fuses are all good in engine bay and behind dash. The mirrior markers,Hood turn singles, and trailer lights work. I did get mice this year but if they chewed a wire I would blow a fuse. I am looking for other ideas of things to check or does anyone know exactly where Fourwinds ran the wires and tied in.
Thanks
Four Winds 33K
NewsW
US
Posted: 04/09/12 01:50pm Link  |  Print  |  Notify Moderator
If they chewed wire it does not follow you would blow fuse.
Work backward from the lamps.. with a Volt meter until you find the problem.
cncdude
Racine, WI.
Posted: 04/09/12 05:05pm Link  |  Print  |  Notify Moderator
I traced the wire all the way across the undercarage. Into the engine bay. through the fire wall. the wire was good but no power. I can't find were it ties into the truck with out tearing the cab apart. Fourwinds never answered the phone. I will go without lights before I rip into the dash.
NewsW
US
Posted: 04/09/12 05:16pm Link  |  Print  |  Notify Moderator
Power box in Front is where they normally tap off for the lights.. check fuse box there.
billw928
Star, Ms.
Posted: 04/09/12 07:18pm Link  |  Print  |  Notify Moderator
I had the same problem with my marker lights on my Jayco Seneca. What i found was a blown bulb in one of the marker lights above the cab.What happened to mine was caulk failed and allowed water to get inside the light and blew the bulb. I replaced the bulb, re caulked the light and no more problems. Hope this helps--this is a common cause.
billw928
Star, Ms.
Posted: 04/09/12 07:23pm Link  |  Print  |  Notify Moderator
I had the same problem with my marker lights on my Jayco Seneca. I found a blown bulb in one of the three marker lights on the front. What happened was the caulk failed and allowed rain water to seep in and blew the bulb. replaced the bulb re-caulked the light. That was two years ago and still working. This is a common problem. Hope this helps.
dlbapm
Escondido, CA, USA
Posted: 04/09/12 09:31pm Link  |  Print  |  Notify Moderator
You might check to see if GM/Chevie publishes a "body builder's book" which contains info (diagrams, connector data, etc.) on how RV builders are to interface to the chassis electrical system. Ford publishes one for each model year and I have found it a big help in isolating problems such as yours.
A/C Inspector
St. George Ut.
Posted: 04/09/12 10:19pm Link  |  Print  |  Notify Moderator
Check out "GM Upfitters .com"
Denny
2006 Seneca 35GS Dmax LBZ, Alli 6spd/ 4" turbo back/ Edge with Attitude/GPS/Bilsteins, air bags/Toyo steers and drivers, Counteract Bead balancing. Ford Ranger toad.
Handbasket
Asheville, NC
Posted: 04/10/12 04:44am Link  |  Print  |  Notify Moderator
What were you using as a ground to check for voltage at the socket? If it was the socket's ground, you may have ground issues instead of + issues.
Jim, "Mo' coffee!"
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory') www.tigervehicles.com
cncdude
Racine, WI.
Posted: 04/11/12 08:14am Link  |  Print  |  Notify Moderator
I checked all the bulbs and they are good. I checked the ground to the frame of the truck. That was good.
I will wait until I get home then check it all again. If I can't find it then I will have to take it in. I will post what I find when it is all said and done.
Thanks for the ideas.
