2inAlabama
Huntsville, AL
The water pump in my '02 Phaeton runs continuously, but I can find no leaks and there is no water at any faucet. It can't even pump water to the outside shower which is 18 inches from the pump in the wet bay. I have 20 gallons of water in the FW tank. Is the water pump bad? Is there a way to test it independently of the rest of the system? Any opinions appreciated.
Just DH & DW
MudChucker
Niverville Manitoba
sounds like the diaphragm is damaged...
yes, you can test it...one simple way is to hook garden hose to the inlet side and see if it can lift some water out of a bucket...
2005 PILGRIM 274RL 5SS
2007 GMC Sierra 2500HD SLT 6.0
MegaJohn
NW Geogia
Our camper has a cut-off valve between the FW tank and the pump... with an inlet to draw antifreeze before the pump. Every season, the first time we use the pump... I forget to open the valve... then wonder why we have no water being drawn from the FW tank.
Does yours have the same setup?
Happy Camping!
John.
Stock 2006 Dodge Ram 3500 MegaCab, 5.9L Cummins, Automatic, 2WD, Dually
- 30' 2006 Pilgrim Interntional travel trailer, dry weight ~7k pounds, GVWR ~9k pounds
- Husky weight distributing hitch, friction anti-sway control, electronic brake controller
Dusty R
Charlotte Michigan 48813
Leave a faucet open for a few minutes. Sometimes it takes a couple of minutes for the pump to push the air out of the lines, and it can't if all the faucets are closed.
Dusty
travelzoo
NW
If you have a city water / tank fill valve make sure it's not in the tank fill position or any where in between.
J Walker
Oakton, Va
I just replaced the diaphragm and lower housing on my Shureflo pump due to leaks. In the process of installing the new part I accidentally got the condition of low pressure and continuous running(never reached cutoff pressure). What I found is that I didn't seat the new diaphragm properly and therefor the mounting screws could not be tightened enough.
I suggest tightening the screws. If that doesn't work remove the screws and diaphragm, lubricate the diaphragm with liquid soap and re-install. If no joy buy a new diaphragm and lower housing. Shurflo can customer service can give a part number and Amazon can get it to your fast.
Jim Walker
2000 34' Damon Ultrasport DP
2009 Malibu
Brake Buddy
John & Angela
Full Timers in Canada, USA and Mexico
travelzoo wrote: If you have a city water / tank fill valve make sure it's not in the tank fill position or any where in between.
Bingo. If you have a valve in the wet bay that allows you to fill your water tank by just diverting the water to the tank, ITS IN THE WRONG POSITION. Essentially the water pump is running in about a 20 inch loop, pumping the same water around again and again and again and again and again "usw"
Tuen it back to the opposite position and you should be fine.
2003 Revolution 40C Class A. 2002 Vanguard 22 foot Class C. Diesel smart car Toad or pulling a 2009 Timeout Tent Trailer.
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
2inAlabama
Huntsville, AL
I figured it out. I had the city water/tank fill lever in the tank fill position, causing the pump to just suck air through the city water connection. I also had the antifreeze fill valve in the wrong position, so this was all just a matter of not understanding how my coach works. Thanks for your help.
Wingnusa
Scott and Brenda Retired and Wingn the USA
Ditto...been there!
Scott and Brenda Schnelle
Jasmine the Schnauzer/Sierra the CKCS
2006 KZ Escalade 36CKB
2007 Chevy C5500
FT Class of '06
Lifetime Good Sam's members
Lifetime NRA member
Sporting Clays Competitor, NSCA #621387
Level 1 Sporting Clays Instructor
NRA RSO
My Site
