RV.Net Open Roads Forum: Ford Transit van as a class B platform?
 > Ford Transit van as a class B platform?
Page of 5
gerrym51
unknown
Posted: 04/11/12 09:37am Link  |  Print  |  Notify Moderator
the e-350,450,550 chassis cab is the backbone of the rv motorized c industry. the transit and sprinter cutaway cannot handle the BIG c's
so the e-350 and the cutaways will be made for a long,long time
NewsW
US
Posted: 04/11/12 10:22am Link  |  Print  |  Notify Moderator
It is technically possible to do a unibody for a E-450 / E-550 form factor.
However, if that is done, RV and Truck makers (they go together) will have a very limited amount of things they can do to a vehicle.
No more adding a box and putting whatever they want on top.
The fuel and material savings from a Ford / GM made unibody truck is a lot less than one thinks... given the volume, the capital costs, etc. involved.
Most steel sold do not come in large / wide enough sizes, nor do the stamping plants exist to process that large pieces.
Thus, a large truck unibody has to be assembled from many smaller pieces.
By the time the cost to make all these little pieces are added up, welded (either spot or laser), the savings is gone.
mumkin
Minot ND USA
Posted: 04/12/12 07:36am Link  |  Print  |  Notify Moderator
NewsW wrote:
Oh... bad news for you...
On comparable payload, the fuel economy savings will be minimal if you are towing.
If you are just using it as a B conversion, there is a modest savings.
A lot less than the 25% claimed --- that is only for "empty" configurations.
Don't mean squat to me... don't tow. Have a Chevy... wouldn't have another E350 if they gave it to me.
Mumkin
2011 LTV Libero
RobertRyan
Australia
Posted: 04/12/12 01:41pm Link  |  Print  |  Notify Moderator
The main drivers for the E series for general work purposes is it's cheapness and familiarity. Transits are OK for Class B's and some smaller Motorhomes. We use light Japanese Trucks for bigger Class C's(31-32ft Long,27,000lb GCWR, tow roughly 8000lb). Their are cutaways for the Transit.Maybe the proposed T450-T550 models are going to replace the E450?. Like the Sprinter , The Transit does not have a E450 equivalent. What type of engine is going to power the T450/550?
* This post was edited 04/12/12 01:49pm by RobertRyan *
NewsW
US
Posted: 04/12/12 02:19pm Link  |  Print  |  Notify Moderator
Things are quite different when you are not upside down like you mates in the land of the Oz.
There are much more to cheapness and familiarity.
Companies, over the last 30 years, have invested decades of engineering work in adapting the E series to numerous specialized vehicles.
From carpet cleaning vehicles (with an industrial cleaner mounted inside), to vehicles that do a zillion of jobs.
Fittings of shelves, special adapters, jigs, tools, and things that just have to be re-done from scratch for a new vehicle.
In the land of the Oz, you never had the benefit of a single line of trucks that hardly changed over 30 years --- and with it.. the accumulated engineering, special fittings that all just work.
So it is much more than familiarity --- it is a major expense to switch to another chassis and OEMs are not about to throw money out the window that they MAY or may not recuperate.
Then there is the issue of cheapness.
The E series is not only cheap to buy, but cheap to own because parts are not generally proprietary, widely available, well distributed, and techs know how to work with it.
That translates into low down days.
May not matter to an RV owner, but if you got $500,000 of gear in a truck that cost $50,000 before conversion, that is a lot to lose if it is out of service for 2 weeks.
Nothing else on the market can promise that combination --- not for the majority of fleets out there.
Try engineering a bucket truck for a new Transit --- and see how much it costs in NREs.
RobertRyan
Australia
Posted: 04/12/12 02:47pm Link  |  Print  |  Notify Moderator
Basically it still comes down to cheapness and familiarity. The E-Series Van as a general work vehicle would be a total failure here,(from what I saw in the US) but I can see how it has become an integral part of US work culture.Change would be very problematic for companies under a lot of economic duress and "jumping into the unknown" would be made with a fair bit of trepidation. The Transit has a lot more variations than the E-Series, making a lot more adaptable. Still for a lot of businesses in the US, it is a case of sticking with what you know.
NewsW
US
Posted: 04/12/12 02:55pm Link  |  Print  |  Notify Moderator
The issue is Non Recurring Engineering Costs.
Suppose I have a set of designs, validated over 30 years for what I need.
There are millions of engineering hours invested in those designs, @ an average minimum cost of $300 to $500 an hour.
What about tooling costs?
If I have to redo the tooling for new fittings for the Transit, how much is that going to cost?
The E series sold over 5.2 million units since 1961.
Why should I throw that stuff out?
The Transit is unproven, it may even be discontinued if it is a flop after a few years, and untried.
Just watch --- the Transit connect will likely be dropped in a bit.
All the upfitters that invested time and tooling in the Transit Connect will see their effort go down the drain after that Turkish bath.
RobertRyan
Australia
Posted: 04/12/12 03:16pm Link  |  Print  |  Notify Moderator
My point not a great time , to start something new. The "validated over 30 years for what I need." does not take into consideration changing circumstances i.e equipment to fix VHS players. Basically a lot of work practices in the US, I found more conservative, a lot less willing to change. So the Transit will struggle, although the E-Series is a Dinosaur and much less capable and adaptable than the Transit, it will still be bought by the bulk of businesses.
NewsW
US
Posted: 04/12/12 03:19pm Link  |  Print  |  Notify Moderator
That is probably why Americans are good engineers.
RobertRyan
Australia
Posted: 04/12/12 03:24pm Link  |  Print  |  Notify Moderator
Well sticking with something that is out of date and not as effective, I do not know about that. You find some very good engineering in a lot of places these days.
Page of 5
