RV.Net Open Roads Forum: Tech Issues: Generator for destination TT? Help me chose>>>
 > Generator for destination TT? Help me chose>>>
kennyd63
Minooka, Illinois
Posted: 04/09/12 04:38pm Link  |  Print  |  Notify Moderator
I have a salem 403FB and I am thinking about getting a generator for backup. In case the power goes out..My question is do they have generators to fit your 50amp prongs[emoticon]?
Thank you..
Post moved from TT Forum to Tech Issues Forum
Moderator - TT Forum
* This post was edited 04/09/12 07:10pm by an administrator/moderator *
2014 Minnie Winnie 2351DKS
2010 Forest River Salem 403FB-Destination Trailer
2014 F150 4X4 Crew Cab
2006 HD Heritage Softail
halibutman214
Oregon
Posted: 04/09/12 04:48pm Link  |  Print  |  Notify Moderator
Thank you..
To answer your question yes they do. My Kawasaki 5000 has one. As far as getting one for a back up however, I doubt you will need or want one that big. You will be told you need everything from a 2000 to a pair of 2000's to the 5000 so I won't help confuse you.
2008 Dodge Ram 6.7 Laramie SRW SB
2012 Keystone Passport 26BHWE
2009 Lance 830 with Tent foldout
20' North River Seahawk Boat
2005 Honda VTX1300
crickeydog
Marietta, Ga.
Posted: 04/09/12 04:50pm Link  |  Print  |  Notify Moderator
Yes...but none small enough to carry. You can barely get by with a 3000 watt generator and use adapters to adapt down your 50 amp plug to fit your generator.
Happy camping!!! See y'all down the road!!![emoticon]
USAF RETIRED 02/1992
DOD RETIRED 04/2014
D/W US GOV/DOJ/DEA RETIRED 10/2010
PULL DOG:
2006 GMC 3500 CC DRW D/A LBZ 4X4 SLT
2004 HOLIDAY RAMBLER PRESIDENTIAL 30' SCD 5'ER
fatmanobx
Russellville, Ar. Home Base
Posted: 04/09/12 05:45pm Link  |  Print  |  Notify Moderator
I have a reciever hitch on the front of my truck and I carry a 4k watt for use where there is no power..
2011 Lance 855
3.5# Minpin named Darcy RIP
Ford F250 Super Duty
boosTT
Milwaukee
Posted: 04/09/12 05:54pm Link  |  Print  |  Notify Moderator
Most people don't have a backup Gen for their house. Why would you need one for an RV? Just one more thing to maintain.
jerem0621
Tennessee
Posted: 04/09/12 06:12pm Link  |  Print  |  Notify Moderator
x2
unless the op is boondocking, then it makes total sense.
thanks
Jeremiah
“Well, here at last, dear friends, on the shores of the Sea comes the end of our fellowship in Middle-earth. Go in peace! I will not say: do not weep; for not all tears are an evil.”
~ J.R.R. Tolkien, The Return of the King
Eycom
32043
Posted: 04/09/12 08:41pm Link  |  Print  |  Notify Moderator
While that may be true, every year that a hurricane even brushes the coast of Florida, there's a run on generators. Seems to be a prevailing thought that it's better to have it and not need it than to need it and not have it.
Then there's the fact that nearly all Class A's rolling down the road, and probably most Class C's, have an on-board gen-set. I've even seen 5er's with built-in generators. Heck! I have an on-board generator in my truck camper. So, I'm not dependent upon a camp ground with electric, whether it's summer in the southeast or winter in the north. I've worked in both areas for days in which power was out due to storms or not available due to the time of year.
Camping styles vary as much as the people who are engaged in it. If you can perceive of a time when a genny will come in handy, get one. If not, I wouldn't worry about it.
All I can tell you is when I was dodging 4 hurricanes in Florida in 04, or got stuck in Buffalo's "October Surprise" in 06, or Hurricane Ike's damage in Ohio in 08 amongst other situations, I sure was glad to have a generator. Because, there wasn't any power where I was for a number of days. I didn't miss a beat. Was cool in the heat and warm in the cold. Watched satellite tv as much as I wanted. Made coffee for the neighbors and linemen working on the poles. To each, his own[emoticon]
RVn Full-time
mlts22
Austin, Texas
Posted: 04/09/12 09:36pm Link  |  Print  |  Notify Moderator
My suggestion: I'd go for a 6000 watt model from Honda or Yamaha (ef6300iSDE for Yammy, eu6500is for Honda), and call it done. You won't be able to get two full 50A legs from this, but you will be able to get 45-50 amps, good enough to run two A/Cs.
As an alternative, a lot of fifth wheels have a generator-prepped compartment. It might be possible to have a pro at electricity and LP gas route piping and install an onboard Onan with a transfer switch.
