RV.Net Open Roads Forum: Travel Trailers: Brake squeal at rest
 > Brake squeal at rest
ScottG
Bothell Wa.
Posted: 04/09/12 05:24pm Link  |  Print  |  Notify Moderator
So today I hooked up the TT for the first time this season and while checking the lights, I hear a high pitched squeal coming from all four brakes (truck is idling BTW). I checked the Prodigy and it's happily indicating ".c.". So I plug and unplug the 7 pin a couple of times and it quits. I get to the shop and when I walk back to the TT, the brakes are squealing again! Note the truck is off at this point. I checked the TT brakes and they were not hot like from dragging. The contacts at the 7 pin are fair (no corrosion) but could use some cleaning.
Whats all the squealing??
Scott, Grace and Wesly
H0NDA eu2000i
skipnchar
Topeka or somewhere else
Posted: 04/09/12 05:52pm Link  |  Print  |  Notify Moderator
Are you sure the squeal is coming from the brakes and not the LP bottles? If it's from the brakes might be a good idea to check the emergency brake switch to make sure it hasn't been pulled.
ScottG
Bothell Wa.
Posted: 04/09/12 06:38pm Link  |  Print  |  Notify Moderator
Yup, the PP tanks were off the trailer and sitting in the back yard. The emergency switch was OK - or at least it was together. The brakes worked normally all the way to the shop (about 6 miles). Trailer is going in for a repaint of its front cap ~ maybe it was scared!
I'm wondering if my 7 pin is just cruddy enough to have some resistance to it or something.
Bob/Olallawa
Kitsap Co, WA
Posted: 04/09/12 09:40pm Link  |  Print  |  Notify Moderator
The magnets are humming because they are getting power from some place. The controller is sending power back, the plug is shorting across, or the emergency brake is leaking.
Lord, grant me the serenity to accept the things I cannot change, the courage to change the things I can, and the wisdom to hide the bodies of those people I had to kill because they pissed me off.
