RV.Net Open Roads Forum: General RVing Issues: Webber 200 gas grill
 > Webber 200 gas grill
HSIKES
Wilmington,NC
Posted: 04/09/12 06:01pm Link  |  Print  |  Notify Moderator
My gas grill won't get very hot. It takes about 20 minutes for it to get to 400* and won't get any hotter. I have it hooked up to the propane outlet supplied to the outdoor kitchen. It is at the recommended pressure, checked by propane company.
Could the burner become clogged? I don't remember it being this way the first year. Removed the burner and washed it with a grill cleaner solution. Not much improvement. I don't have a hot large blue flame, but a very low blue flame. Have to look closely to see it.
While a part, I saw the gas orifice and was wondering if I should drill this a little larger? Would more propane do better?
Any suggestions?
Horace & Bobbi
DRAKE - Yellow Lab (rescue dog)
2005 Fleetwood Providence 39 L; 4 slides; 350 Cat
2000 Saturn LW TOAD
2009 Buick Enclave CLX 2
Preach the gospel at all times. And if necessary.....use words.
Ka Ron
Kelowna
Posted: 04/09/12 06:13pm Link  |  Print  |  Notify Moderator
Yes, it may be the regulator is not functioning properly.
Do not drill out the orifice as the size is for the BBQ design.
That model is only 12000 BTU and it may never get above 400.
If the flame is smaller than last year, then it sounds like a regulator problem.
Join Us For A Trip Down The RV Highway
past-MIdirector
Michigan
Posted: 04/09/12 06:32pm Link  |  Print  |  Notify Moderator
Unscrew the orifice out and check the hole also I've had to clean the area where the orifice screws in with a q-tip that been dipped in alcohol even once in a while..
pbensen
Canton, Michigan
Posted: 04/09/12 09:16pm Link  |  Print  |  Notify Moderator
Hello,
Try unscrewing the bottle then reconnecting it and let it sit for 5 minutes before you start the grill up. I heard that there is some kind of gas limiting device that can cause the gas flow to be restricted if there system develops a big leak. I have a Webber 220 that I have connected to a 20# cylinder. There is a gas limiting valve in that in the hose at the connector that plugs into the tank.
Paul
2002 Jayco 324G 33ft quad bunk 7200# max loaded (long trip)
2001 Econoline E-150 Traveler 5.4L w/3.73:1 rear gears
Hensley Arrow hitch and Brakesmart brake contoller
RedRocket204
Colorado Front Range - Got Elk?
Posted: 04/09/12 09:57pm Link  |  Print  |  Notify Moderator
Jim Cindy wrote:
Have you removed the regulator from the Weber, the camper grill outlet already is regulated at you tanks.
Yep.
Hook a standard propane bottle directly to your Weber 200 grill (no other regulators in line except for the Weber regulator) and it will most likely work like you would expect.
I love me some land yachting
Jim Cindy
Northcentral, PA
Posted: 04/09/12 07:57pm Link  |  Print  |  Notify Moderator
PBH Portable Beach House
2008 GMC 2500HD Duramax Allison
2009 Cameo 34CK3
MorRyde IS, Disc Brakes, G614's
PullRite Super Glide Hitch
Propane fueled Yamaha EF 2400is
Bill1374
northern New York
Posted: 04/10/12 09:32am Link  |  Print  |  Notify Moderator
The Weber regulators have been know to fail. I'm on my third now. When the flame is right, I don't think there's a better grill out there.
Bill
2011 Hitchhiker Discover America 345RSE
2006 Dodge quadcab,dually 2 wheel drive
Here'n'There
Posted: 04/10/12 09:58am Link  |  Print  |  Notify Moderator
Agree with the first and second points except that the grill SHOULD be heating up greater than 400 degrees. I replaced the regulator and burner tube in my Q120 - it gets up over 600 degrees.
Here'n'There
2009 Carri-Lite 36SBQ 5th Wheel
2008 Dodge Ram 3500 Quad Cab Long Bed Diesel Dually
On the road with Here'n'There
Role of the C133 in Viet Nam
Ron3rd
Upland, CA USA
Posted: 04/10/12 06:52am Link  |  Print  |  Notify Moderator
X2, that's likely your problem. You need to take the Weber's regulator off as you're drawing regulated propane already. A quick test if you want to verify is simply screw on one of those disposable tanks and see how the Weber works. Also, Weber's tech support is really good, you can email them too. Great service.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
kchotrod61
Kansas
Posted: 04/10/12 07:25am Link  |  Print  |  Notify Moderator
If you get this figured out post it here please. I have the same issue. I have tried using my 20 lb tank and a single screw on can with the same result. It will barely heat up a hot dog. I have cleaned all the connections, burner tube, etc. and finally gave up and went back to charcoal. Used it one season so I am assuming the regulator is faulty.
