RV.Net Open Roads Forum: When do you decide to level left to right??
 > When do you decide to level left to right??
Page of 5
christopherglenn
a little over an hour from Yosemite
Posted: 04/09/12 08:34pm Link  |  Print  |  Notify Moderator
I open the door and put a little bubble level on the floor. I level left to right before dropping the trailer, and outting the family in it. I carry a small selection of 2x8 blocks for leveling. Sometimes I put one block under one tire, this weekend I had 4/6's under 2 axles at the FIL's house. After dropping the trailer I level front to rear, then the X-chocks go on.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
restlesswind
Fulltime
Posted: 04/09/12 09:08pm Link  |  Print  |  Notify Moderator
I use a 2ft level to check for plumb on the outside wall (between the axles)What I have found,is that if that point is plumb,then the trailer is really close to level side to side.Depending on how it is off plumb,I have,over time,figured how many "Lego"blocks I need on
which side,to get thing level,or close enough to level. Close enough is when it is not too noticeable when walking around inside.
After the side to side routine,it's pretty simple to run the front jacks up or down to get the trailer level front to rear.( again,I have found that if the basement floor is level,front to rear,it's time for a "cool one".
'04 33.5 CKQG Hitchhiker Discover America
04.5 Dodge 3500 CTD SRW
Pac Brake,Max Brake
Fulltimers since '06
stickdog
29.820224, 81.94542
Posted: 04/09/12 09:09pm Link  |  Print  |  Notify Moderator
These are what we use, level your trailer with a torpedo or masons level when you have it where your comfortable apply these: http://www.campingworld.com/shopping/item/rv-levels-set-of-2/47550 where your front jack controls are one on the front and one on the side.
I spot the trailer where needed for utilities and slides. Then check the level on front for side to side. After a few times you'll know how many boards or blocks you'll need to level. Drop the board along the tires, pull up till I'm slightly past the front edge DW moves them over inline with the tires and I backup on them. Recheck level, if good and it usually is, next check how much front needs then drop the front stabilizers.
9-11 WE WILL NEVER FORGET!
04 HitchHiker DA LS 33.5 RLTG
09 F350 CC DRW 4X4
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
newk
Gillette, WY
Posted: 04/09/12 10:05pm Link  |  Print  |  Notify Moderator
I have a small rv bubble where I can see it in rear view mirror, BUT it's too small for me to see well. I wish I had a bigger one (maybe this summer). I check it as I back (or pull) into my spot, and if it's obviously low on one side, I put 2x6s down to back onto.
blkdodge
Arizona
Posted: 04/09/12 10:16pm Link  |  Print  |  Notify Moderator
I back in or pull in unhook from TV and push the autolevel button, grab a cold one and let it do it's thing. Dont get mad I used to do all by hand also.
2012 Dodge 3500 DRW/2012 Heartland Landmark San Antonio.
Splashers3
Oakville, MD
Posted: 04/10/12 03:57am Link  |  Print  |  Notify Moderator
After figuring out an accweptable distance in relation to the utilities, wife uses a 2' level at door (which is close to the axles). If needed we use the lego blocks - I pull fwd, she lays them out, I back up and stop when she tells me its OK.
It's not that hard.
2008 GMC Sierra C/C 2500HD D/A - w/Titan 52Gal tank
Ride Rite Airbags, Trail Air Pin Box, Garmin Nuvi 1450LMT,
Blue Ox Bed Saver, TST Tire Monitor, Yamaha EF2000is,
2009 Cedar Creek Silverback, GII, 32 WRL w/ XPS RIBS
greende
Syracuse,NY
Posted: 04/10/12 04:09am Link  |  Print  |  Notify Moderator
Have always used a 2' level in the doorway. Works for me.
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
Lantley
Ellicott City, Maryland
Posted: 04/10/12 04:37am Link  |  Print  |  Notify Moderator
I now have the auto level feature, however prior to that I used a 2' level at the door.
07'Duramax dually,12'Open Range 399BHS
Hawkshead TPMS,Hensley BD3,Killerbee exhaust brake
Blue Ox Bedsaver,air bags w/compressor
Arvika pin box bike rack,Bak Flip tonneau cover
5500 Onan LP,EMS-HW-50
14'Porta Bote w/8.0 Nissan
Vu Cube 2000,Splendide 2000S
ExRocketScientist
Laurel, MD
Posted: 04/10/12 06:06am Link  |  Print  |  Notify Moderator
HTT to be? wrote:
R to L is the first thing to be corrected. While we are still hooked up we check the level to see if we need to lay a block or two down to have her sitting level. So we back her in to the exact spot we want the trailer, then ck for r/l level, if needed, pull forward just enough to lay blocks needed, then back her up and ck she is right. Then we put in chocks and unhook
X2 on it being the first thing to be corrected. I have a small level attached to the back of the pin box.
ERS
coolmom42
Middle Tennessee
Posted: 04/10/12 06:25am Link  |  Print  |  Notify Moderator
This.
2006 Toyota Sienna
Single empty-nester in Middle TN
Page of 5
